VTEC Oil Control Solenoid…..
Old Sep 14, 2021 | 03:12 PM
Padre Dave's Avatar
Lightbulb VTEC Oil Control Solenoid…..
Hey group….the guy who does my warranty maintenance on my RDX is the same guy I took my Mazdaspeed 3 when I owned it. Last oil change he told me that I have an oil leak near my timing gear/valve cover and I should take it back to Acura as it is under the powertrain warranty. So, I took it back to Acura of Tempe where the excellent Service Manager Abel fixes me up.
Turns out it was the VTEC Oil Control Solenoid that was leaking oil. I don’t know if it was defective or just a leak. Anyway, 4 hours later they returned my car saying all is good. Yes, it was warranty. So, something to look out for when you take your car in or if you do your own changes to inspect for on the engine.
Blessings!
Old Sep 14, 2021 | 03:29 PM
Thanks for the heads up!
odd tho! often times, it's the gasket that fails that leads to leaks. Wondering what Honda changed. wondering why the gasket failed.
Old Sep 14, 2021 | 05:42 PM
Wow, how many miles on the car and what year?
Old Sep 14, 2021 | 07:59 PM
Padre Dave's Avatar
Sorry, for those who are interested, mine is a 2019 A-Spec with about 42,000 miles on it.
Old Sep 15, 2021 | 09:14 AM
leomio2.0's Avatar
This was an issue on 2G CR-V's too. How is this still an issue?
Do you know the location of it? On the K24 in the CR-V, it was on the rear passenger side of the head.
Old Sep 15, 2021 | 09:31 AM
EFR's Avatar
EFR
Wow....mine is a 2019 A Spec and has 9500 miles on it.
Old Sep 15, 2021 | 07:52 PM
russianDude's Avatar
You have any pictures of the location that was leaking so We can check ours?
Old Jan 11, 2022 | 01:24 PM
jeh1982's Avatar
I have a really rough idle and have suspected this was the issue for a while. OP: did what alerted your tech to the problem?
Old Jan 11, 2022 | 02:21 PM
sonyfever's Avatar
Rough idle usually is related to vacuum, fuel, or ignition. The solenoid oil leak is literally oil leak around where the solenoid is. The symptom is nothing new, it is a well known source of oil leak on higher mileage K24.
flipper316
Dec 21, 2020 11:40 PM
visi_d
ILX Problems & Fixes
Aug 30, 2018 09:34 AM
codog11
Nov 1, 2007 07:51 PM
bjo3030
Apr 16, 2006 04:15 AM
