Sunroof Sunshade wont close
Bring it to the dealer as there is a technical service bulletin for it.
Resetting the Panoramic Glass Roof Motor-Control and Power Sunshade Motor-Control Unit
https://acurazine.com/forums/third-g...letins-970256/
I mainly open the glass roof when the RDX was parked under the sun for a long period of time to rid off the hot air inside.
Yesterday, the glass roof would not keep closed when pressing the auto-close. It would close and then open back up again.
Luckily, I was able to close it by continue to press and hold the close switch. This morning, it would close correctly from time to time, but not always. Going to see dealer tomorrow...
I had that issue the first day I got my RDX. For me they first tried calibrating but didn’t work. Then found out the sunroof frame was bent and replaced that. But over time it keeps loosing calibration and end up replacing the sunroof switch/ module .
I have a 2019 A-Spec RDX. I brought it to the dealer over a month ago because the sunroof was dead. They are STILL trying to figure out how to fix it! They have replaced every part including the motor and entire frame!
They say the TSB is not related to the problem on my car. I really don’t think they have any clue. They keep telling me they are waiting for parts! Most troubling, Acura corporate doesn’t seem to care either, they have done nothing other than call the dealer a few days after I called them!
FRUSTRATING!
FRUSTRATING!
Today is day 37 and the dealer said it was ready to go. NOT! I get down there and the sunroof clearly does not align properly and some of the rubber mounding is sticking up at various points around the perimeter! They say they can fix it tomorrow.
Acura customer service has been absolutely no help! Come on Acura, we all know you can do better!
It turns out there is a known issue with the RDX sunroof. The manufacturer has redesigned some parts to correct the problem. The problem now is there is a LONG backlog of cars at dealerships across the country needing this fix! I finally got my car back on the 38th day!!
I made the mistake of using my sunshade again and it is stuck open. I think I've only used it 10x in the last year, but its going back to the dealership for a repair. The previous repair was a complete replacement of the motor control unit.
SazzzTX1
5G TLX Problems & Fixes
May 12, 2020 08:48 PM
