side mirror clicking/struggling in reverse
My passenger side mirror started to click/struggle when it's trying to tilt down when I am putting car in reverse. Is there a simple adjustment needed, or its an indication of a mechanism failure?
It only does this on passenger side. I have my mirror switch set to the right to only have passenger mirror tilt on reverse. I tried switching it to the driver mirror, and it had no issues tilting when putting car in reverse.
it makes no contact with housing
It adjusts down, but I have not measured how much down compared to the driver side.
I cant tell if it should continue to tilt down even more, or its in a final position when it starts clicking.
The tilt angle is OK with me, just wish it would not click…
I seem to have resolved it for now, when car was parked and turned off, I gently moved mirror all way down.
then start car, set memory position to reposition the mirror and it started to work.
Strange, maybe its intermittent issue …
Failing motor mechanism
Sounds exactly like my TL mirrors were misbehaving. The motors that power the mirrors were failing on both sides with the right side much worse due to the regular tip down in reverse. I replaced them with new oem motors. Hardest parts is removing the mirror from the housing.
That would suck if motor starting to go, I dont think they sell motor separately and you need to buy entire assembly for like $600.
It works now, maybe gears just need cleaning/lube or adjustment.
What’s interesting, I had my mirrors for long time in neutral position, so there is not much usage for motor control to go bad that soon.
Jackistan
Aug 18, 2025 09:59 AM
sr20bet
Mar 7, 2016 02:23 PM
