Navigation Voice while on phone call
Old Oct 16, 2019 | 08:52 PM
m711's Avatar
6th Gear
Hi, I was wondering if I'm missing a setting. In other cars I've owned, while using navigation, if I was on a call it wouldn't interrupt with voice directions. On my RDX, the navigation voice interrupts calls which are mostly business calls and very disruptive. Other cars I had you could set the navigation voice to off when it recognized you're on a call. Does the RDX have this option and I'm missing where it is?
Old Oct 18, 2019 | 12:20 PM
Mark S Long Island's Avatar
while I don't think there is an off setting to stop the voice I think the following works. Simply manually lower the voice while its speaking. you may do this either by the volume control on the wheel or on the radio. when you want to override the mute mode you just did, prompt the voice in navigation & make it louder.
Old Oct 18, 2019 | 02:41 PM
m711's Avatar
6th Gear
Thanks I was hoping there might be a better solution but it's better than current situation.
Old Oct 18, 2019 | 08:44 PM
kboo74656's Avatar
Go to settings, system, scroll down to advance options, interruptions, interruption mode, and pick which option you want.
Old Oct 26, 2019 | 11:26 PM
m711's Avatar
6th Gear
Unfortunately there isn't an option there unless I'm misunderstanding available options in that menu.
Old Oct 27, 2019 | 06:38 AM
kboo74656's Avatar
It’s right there staring at you.
Old Oct 27, 2019 | 03:24 PM
mcpagano's Avatar
I'm not the OP but I didn't know this option existed either. Thanks, I found it.
Old Oct 27, 2019 | 06:01 PM
kboo74656's Avatar
No problem and your welcome. In my down time I poke around in all the menus to see all the options available.
Old Oct 28, 2019 | 04:38 AM
Cuzz's Avatar
Lol, I tend to do that too. That way when I want to change an option I know I can because I remember seeing it before. My problem is that I can’t remember where I saw it last time and have to search all over again.
EE4Life
3G RDX (2019+)
21
Aug 10, 2019 12:29 PM
Elaine Sachs
ILX
Dec 11, 2016 02:17 PM
th5620
Mar 17, 2015 09:34 PM
mightl
May 4, 2011 10:48 AM
Andrew McCarthy
42
Mar 12, 2006 10:40 PM
