Name this Problem...
Old Aug 26, 2020 | 07:52 PM
bcarroll's Avatar
Question Name this Problem...
I could use some help diagnosing a developing problem...
I'm not driving as much - like most of you these days because of covid, but I still drive almost every week and when I do drive it is at least 25-minutes which I expect should be sufficient to keep everything in order.
Car is ~16 months old, ~12k miles.
Auto Idle Stop has not worked for about 6-weeks - worked on most drives prior to that.
I tried the Auto Idle Stop "fix" involving opening the hood and starting the car about 2-weeks ago, but still no auto idle stop
The car "seems" less eager to start the last several times (slow cranking)
After today's drive, I checked the battery which read 11.89 VDC - I was expecting 12.4 or more
I started the car (started right up) and checked the battery with the car running which read 14.4 VDC - meaning the alternator is ok?
Do I have a die-ing battery? How can I confirm this - and replace it before getting stranded?
What other possibilities match these symptoms?
Thanks for your help
B
Old Aug 26, 2020 | 08:17 PM
yes, dying battery.
it should hold at 12.2-12.4 volts when the car is off.
anything less, battery is no good.
Old Aug 26, 2020 | 08:26 PM
JB in AZ's Avatar
Should be under warranty, see your dealer.
Old Aug 26, 2020 | 09:04 PM
I wouldnt stick to a honda battery if it died in less than 2 years.
Interstate batteries are great, so are anything made from Johnson Controls.
pco0106
5G TLX Problems & Fixes
Dec 4, 2019 11:57 PM
9SpeedTran
48
Apr 24, 2019 07:32 PM
binary_10essee
Jul 8, 2014 07:28 AM
MadeMan716
Aug 2, 2011 07:28 PM
mosCLtypeS
2G CL Problems & Fixes
Oct 17, 2005 01:30 PM
