Key Fob Memory Loss
Old Aug 10, 2019 | 08:02 AM
robnalex's Avatar
Key Fob Memory Loss
Our RDX no longer recognizes the key fobs for driver 1 or driver 2. We have to push the memory 1 or 2 buttons in the car to get the seats, etc. to adjust for the appropriate driver. Anyone have a fix for this?
Old Aug 10, 2019 | 11:47 AM
Burger Steak & Eggs's Avatar
I'd try new batteries in the fobs first......although one would think they would last a bit longer. Do you use the fobs a lot outside of ingress, i.e. remote start?
Old Aug 10, 2019 | 03:07 PM
robnalex's Avatar
Batteries don't seem a likely cause. The car's only 7 months old and one of the fobs is only 3 months old (dealer had lost one and gave us a new one when we purchased in May). We don't use them for anything except locking/unlocking. They're still working for everything except the memory for driver 1 and 2.
Old Aug 10, 2019 | 05:45 PM
robnalex's Avatar
Has anyone programmed a fob for the 2019/20 RDX? Programyourremote.com says: "There is no manual on board procedure to program a keyless remote to this vehicle. This vehicle requires special equipment be connected to the vehicle to program the remote."
Old Aug 10, 2019 | 06:39 PM
MT-RDX's Avatar
Check the settings at Vehicle : Driving Position Setup to see if the memory link has been turned off. Refer to the RDX Owners Manual, page 347.
Old Aug 11, 2019 | 06:40 AM
robnalex's Avatar
Thanks! I'll check that out, however, the memory buttons still work- but that does say "link".
Old Aug 11, 2019 | 05:13 PM
robnalex's Avatar
Without doing or changing anything the car is now implementing the memory settings for driver 1 and 2 based on the key fob in use. Go figure!? I did check the settings after the fact, and memory link is turned on.
Old Aug 11, 2019 | 05:56 PM
It almost sounds like another ramification / slight aside of the infotainment debacle.
Old Aug 12, 2019 | 07:06 AM
DHood's Avatar
Question
Did the Dealer give you the "Correct FOB". What I mean is that they are marked on each FOB either with a number 1 or number 2. If the dealer gave you a duplicate of what you already have i.e. two Number 1 then I wonder if that would cause a problem?
Just a thought.
DavidH
Old Aug 12, 2019 | 08:08 AM
robnalex's Avatar
Yes. The fobs are correct. They worked. They stopped working (only for driver memory). They're working again.
Old Aug 13, 2019 | 01:22 PM
Twaeball's Avatar
I've had this happen couple of times. In my case I finally figured out that when the key fob and my cell phone are together the car does not pickup the key fob for seat memory. Car still starts fine. I had a habit of having both in the same front pants pocket or placing both in center console together. I keep them separated and no more problems.
Old Aug 13, 2019 | 02:50 PM
robnalex's Avatar
I don't think that's what's happening with us. Who these days doesn't have a cell phone with them when getting into their car? Even so, we never have them in the same pocket. But should that really matter?
Old Aug 29, 2019 | 10:41 PM
robnalex's Avatar
Mystery Solved: The key fob memory link not working was related to a bad battery. Battery replaced (under warranty) - problem solved.
Jax4u2c
Nov 29, 2017 06:59 AM
gabetknox
1G RDX (2007-2012)
Sep 30, 2017 09:34 AM
clemsonsteve
2G RDX DIY & FAQ
Apr 30, 2017 10:46 PM
abanytime
Jul 18, 2015 06:21 PM
mfrench13
Jun 21, 2011 01:47 PM
