Harsh shifting 2nd to 3rd
Old Sep 20, 2018 | 03:21 PM
  #81
acuraada's Avatar
Originally Posted by zroger73
New owner here (5 days and 277 miles) with rough 2-3 and sometimes 1-2 and 3-4 shifts. Mine was built in '07/18 with a VIN ending in around 5,800.
I had a 2018 Accord Sport 2.0T 10AT and it behaved similarly during its first several hundred miles. It improved over the 4,000 miles I owned it, but would still "buck" during shifts in lower gears at times.
This behavior was frustrating in a $31K Accord and even more so in a $47K RDX.
I also have a very pronounced vibration that can be felt and heard while stopped in reverse while the engine is cold. It doesn't occur in drive or after the engine warms up.
sorry to hear, did you test drive before delivery? I would take this to the dealer immediately to document such issue, we all know they don't have a solution but when and if they do, you will be on the list.
Old Sep 20, 2018 | 04:03 PM
  #82
zroger73's Avatar
Yes, but the test drive was very short - just enough to make sure it actually had an engine and transmission and that the A/C and radio worked. I trade vehicles often and sometimes buy them with only visual inspections instead of test drives. I'd never seen an RDX in person or driven one until I bought mine this weekend. I did document the issue with the dealer. If a software update will address the issue, I'll have it done. If the transmission has to come out, I'll live with it.
Old Sep 20, 2018 | 05:27 PM
  #83
DuBignon's Avatar
6th Gear
Another RDX owner here with a disappointing transmission. This is my first post
Have owned the car for 2 weeks/1,100 miles and ours was serviced today. Started the visit with a drive accompanied by a technician, then let him drive as well. He observed the same hard shifts. Otherwise, same process as described by others (snap shots, coordination with tech line), but followed by a recommendation to replace the transmission. Process will take at least a week.
I've driven 4 different '19 RDX (2 Tech models, 2 Advance, all FWD) and experienced different levels of transmission performance. All had a hard shift between 2nd and 3rd, 2 (Advance models) were noticeably more refined otherwise, and the remaining 2 had erratic shifting below and (less often) above that gear range. Used Comfort, Sport, and Sport+ modes. In the better performing models, Sport mode seemed the most refined option. Unfortunately, the model we purchased was the worst of the lot. Ironically, the loaner we have now is the best. While I'm glad it was a productive service visit, I'm anxious to see what the outcome of this will be.
Originally Posted by code3_rdx
Finally received a call from the service manager and they have had my new RDX for 3 weeks now. They went thru the procedure of taking the snap shots 3 separate times then talked to the tech line. No go! He said they had to drive so many miles at certain speeds and then take the snap shots. So again they did it 3 more times and nothing! My car is not taking the fix that the tech line is suggesting. So after 3 weeks, they have given up and have approved a new transmission for my brand new RDX. A part of me is happy it is being fixed but the other part of me is sad they will be tearing apart my brand new car.
@code3_rdx, any update following your transmission replacement? Could use some good news
Old Sep 21, 2018 | 11:42 AM
  #84
ed_k's Avatar
I got RDX 19 Base SH-AWD. Harsh shifting (jerks) at slow acceleration 10-15 mph.
Old Sep 21, 2018 | 09:36 PM
  #85
shodge's Avatar
Again, I am going to ask this: Does anyone with a A-Spec have this problem? Please post.
I have driven a NEW A-Spec without this issue...
-Stan
Old Sep 22, 2018 | 08:01 AM
  #86
securityguy's Avatar
It is inherent in the tranny design and has nothing to do with the model or trim selected. All of the 10-speeds are the same. Based on mechanical tolerances, some may show more more signs than others.
Old Sep 22, 2018 | 08:54 AM
  #87
acuraada's Avatar
-Stan
i think you have answered your own question. Also, if you search other threads and past posts, you will have your answers.
basic forum courtesy
Old Sep 22, 2018 | 01:58 PM
  #88
shodge's Avatar
I have read the other threads unless you can offer ADDITIONAL information, it would seem a new conclusion can be reached that this is some kind of a software issue in the models other than A-Spec. (BTW - the lack of data is NOT an answer) I as also aware that the underling power train components are the same. The specific reason I posted the same question a second time was to see if ANY A-spec users were having the issue and had not reported it.
It seems we really need some kind of FAQ created for these issues. It may help Acura determine the problem / solution. It will certainly help my data in communicating the problem to them....
-Stan
Old Sep 22, 2018 | 04:27 PM
  #89
dukeh62's Avatar
-Stan
A-Spec does it. Mine has it, and have talked to other owners who have confirmed the issue as well.
Old Sep 22, 2018 | 09:00 PM
  #90
tobey457's Avatar
I have an a-spec sh-awd. Shifting is and has been flawless in all gears since day 1, just hit 1k miles. Build date was 7/23.
Old Sep 23, 2018 | 04:16 PM
  #91
shodge's Avatar
This is weird. The A-Spec I drove was a FWD... The implication is not all RDX's have this issue...
-Stan
Old Sep 23, 2018 | 08:03 PM
  #92
Master47's Avatar
I think there are varying levels of the issue crossed with varying levels of sensitivity by drivers to the issue. I notice it on ours, but if they told me it was tranny replacement I think I could learn to live with it, and just like most other things, sensitivity to it will diminish over time.
Old Sep 24, 2018 | 09:42 AM
  #93
Stew4HD's Avatar
You do get used to it. I have about 4200 miles on mine now and rarely even notice it. I have either changed my driving habits or just ignore it.
Old Sep 24, 2018 | 03:35 PM
  #94
code3_rdx's Avatar
8th Gear
@DuBignon Got a call from the dealer today and they received the new transmission on Friday. He said installation should be completed by Thursday or Friday of this week. I miss my RDX...
Old Sep 24, 2018 | 04:54 PM
  #95
acuraada's Avatar
-Stan
why is it weird? Many have already reported this across all trims. Go check out Reddit.
It is great that you want to collect data for Acura but the best way to do this is report it to your service rep and keep complaining. Acura is already aware, I posted the video interview of engineering chief not too long ago. This is not a A-spec or AWD issue. Not everyone experiences it. The two test vehicles I drove, one advance and one Aspec with less than 100 miles on them didn’t have it.
I don’t think there is an easy answer but my money is on hardware, parts or assembly.
Old Sep 24, 2018 | 08:18 PM
  #96
DuBignon's Avatar
6th Gear
Appreciate the update. Was told roughly the same, but would be surprised if the work on ours is done by week's end. Please keep us posted on the outcome, will do the same.
Old Sep 26, 2018 | 06:11 PM
  #97
DuBignon's Avatar
6th Gear
Picked up our RDX this afternoon, two days ahead of schedule. Relieved to report that the new transmission seems to have eliminated the hard shifts. Upshifts are smooth, downshifts are noticeable on occasion, but well within tolerance; repeatable hard shift between 2 and 3 is gone. Was told a 'new computer' was part of the service and 500 miles of driving would be needed for a full transmission relearn. Was only able to drive ~8 miles this evening, all in Comfort mode, but so far, so good
Old Sep 27, 2018 | 12:08 AM
  #98
code3_rdx's Avatar
8th Gear
Unhappy
Good outcome so far! Time will tell. Apparently my dealership did not receive my new transmission yet. It was delivered to the wrong dealer!!! So now i have to wait until the middle of next week to get my car back. Will update everyone then.
Old Oct 4, 2018 | 12:44 PM
  #99
Meto's Avatar
The last time I dropped off my vehicle for service, I was lucky enough that the District Service Manager was there.. During their time with my vehicle, they resolved this problem with what he called a "Vehicle Break-In" procedure. He didn't go into detail and it wasn't on my service ticket, but he said that anyone that is experiencing this issues should report it to their dealer and take the vehicle in for service.
Old Oct 4, 2018 | 02:00 PM
  #100
DuBignon's Avatar
6th Gear
As another data point, the tech that worked on our RDX was advised to perform 'the break in procedure' (from his notes) following the first series of snap shots sent to techline. It failed to improve the shifting issues, another set of snap shots were sent to techline, then the transmission replacement was recommended. Sure wish the break-in had worked for us.
Unfortunately, the transmission replacement doesn't seem to be a catch-all fix either. Our RDX is regressing after just one week with the new transmission. Reserving judgment for now and continuing to follow their instruction to allow 500 miles for the transmission to relearn. One positive is that the particularly hard shift between 2nd and 3rd gear does still seem to have been resolved.
Old Oct 4, 2018 | 02:15 PM
  #101
zroger73's Avatar
Yet another data point is that at just over 1,000 miles now, my 2-3 shift is unquestionably becoming less jerky. It still borders on "unacceptable", but I'll give it some more time. Unfortunately, the major vibration that can be felt and heard inside the cabin while stopped in reverse when the engine is cold hasn't improved. I've resorted to backing into my garage in the evenings so that I'm not subject to the vibration when I leave for work in the mornings. I shouldn't have to do that in any vehicle - let alone in this vehicle.
Old Oct 4, 2018 | 03:16 PM
  #102
ednigma's Avatar
I'm not sure if this has been thought of, but since you mention it happening when the engine is cold, it might be a problem with the engine mounts. Many engine mounts are hydraulically damped and maybe the hydraulic fluid is too thick(defective fluid or manufacturing?) when cold and lets engine vibrations through to the chassis. Also, my older BMW has something called an ICV (idle control valve) whose purpose is to help smooth the idle when the engine is cold. Newer cars may be fully controlled by the engine computer, but it might be combination of the engine mounts and poor idle control by the engine control computer.
Hope this helps
Old Oct 4, 2018 | 03:57 PM
  #103
zroger73's Avatar
Hope this helps
I had a similar thought regarding engine mounts, but I don't think it's related to the temperature of the mounts since the vibration diminishes within a minute or two.
Virtually every vehicle on the road has had an idle air control valve since fuel injection became common in the 1980's. Once electronic throttle control became common by the mid-2000's, the throttle blade was used for idle speed control instead of the idle air control valve. The function of the idle air control valve is not to "smooth the idle" per se, but to simply maintain the desired engine idle speed under various loads and operating conditions.
Interestingly, the engine idle speed while stopped in reverse with a cold engine is a few dozen RPM's higher than while it is in drive. This doesn't make any sense. My 2018 Accord had the same engine and transmission as the RDX and it didn't exhibit these characteristics. The 1-2-3 shifts were a bit jerky on occasion, but nothing like what RDX owners are experiencing.
Old Oct 5, 2018 | 06:55 PM
  #104
Bigmanibids's Avatar
4th Gear
I have a new 2019 RDX. I HAVE NOTICED FROM A STOP THE CAR ACCELERATION NOT SMOOTH IN LOW GEAR. IT APPEARS TO BE JERKY
Old Oct 6, 2018 | 10:54 AM
  #105
Steven Tuttle's Avatar
Hi, I’m new to this forum and own a 2019 A-Spec SHAWD and have about 3k miles. I have opened an Acura case #4155113 (technical case) and client relations case #08986310 for this “California stop hesitation” issue. My RDX will rev higher, but not engage the transmission for 1-3 seconds when doing a California stop. The issue is easy to replicate and is more pronounced when turning. This has almost caused a couple accidents for me already.
Acura’s initial response was that this was to avoid spinning the car out. This obviously makes no sense on a SHAWD car, so I escalated with Acura. It is working as designed (I’m an auto broker and confirmed with other clients) and I would consider any car that ignores throttle input to be a safety issue. My Acura dealer has had my RDX for 3 weeks now, trying to get a regional Acura representative to engage. I live in Phoenix and am working through Acura of Peoria.
Old Oct 7, 2018 | 04:09 PM
  #106
4th Gear
Jerking of new 2019 RDX
i have my car for 2 weeks with about 700 miles. I also have the jerked acceleration from a full stop. I noticed that if i let the car roll for a second or two before hitting acc lerator the issue is 90% resolved. Weird
Old Oct 7, 2018 | 04:13 PM
  #107
So got to drive the wife's RDX today to Church. Noticed that it has about 1100 miles on her now. We are not experiencing the harsh shifting or jerkiness at all. When it was "new", I did notice just a tad of the shifting issues (and wouldn't call it harsh) but today I experienced nothing and my wife has said it's been smooth as well during her normal driving. On our latest tank, she got 28.2mpg.
Old Oct 7, 2018 | 05:04 PM
  #108
MI-RDX's Avatar
Originally Posted by securityguy
...On our latest tank, she got 28.2mpg.
WOW! What does she do?... Drive downhill with a tail wind all the time?
Old Oct 7, 2018 | 05:10 PM
  #109
She doesn't drive at all like I do...very easy on the gas and it's flat in FL which helps a lot too.
Old Oct 8, 2018 | 10:25 AM
  #110
zroger73's Avatar
The 10AT contains three brakes (B1, B2, and B3) and three clutches (C1, C2, and C3) that engage in specific combinations to select the desired gear.
During the 2-3 shift, clutch C2 is released using clutch pressure control solenoid valve C while clutch C3 is applied using clutch pressure control solenoid valve B.
Clutch C3 is also applied when downshifting from 6th to 5th and when shifting into reverse.
The rough shift could be caused by:
1) Clutch C2 disengaging a bit early causing shift flare followed by shift shock when C3 engages.
2) Clutch C3 engaging too quickly causing shift shock.
3) Clutch C3 grabbing due to more friction than the shift timing was programmed for.
I am by no means a transmission expert, but I do understand some basic principles of operation and don't understand why this 2-3 shift issue can't be easily resolved with a software update.
Old Oct 8, 2018 | 12:10 PM
  #111
OliveBread's Avatar
Took my delivery on September 26, 2018; car was being built on end of August somewhere between the 27th & 31st, 2018.
I've driven about 500 miles so far and have not experienced hard shifting between 2nd and 3rd. Smooth shifting so far. 60% city (hills), and 40% highway.
I've been driving on Comfort (haven't touched Sport/Sport+), and haven't really "pushed" the car hard. Still doing the break-in period style driving (steady acceleration/no lead footing/no redlining/etc.).
Old Oct 8, 2018 | 02:41 PM
  #112
B25Nut's Avatar
We experienced the harshness in shifting for the first two weeks, then switched to driving only in Sport mode, which eliminated 90% of the problem. With over 2k miles on it now, the transmission is operating very smooth with no problems.
Old Oct 11, 2018 | 06:56 PM
  #113
code3_rdx's Avatar
8th Gear
@DuBignon I finally got my car back from the dealer after 7 weeks of missing it. Apparently my dealer ordered a new transmission and for some reason it was delivered to the wrong dealer. FedEx was sent to pick it up and take it to my dealer and they refused the pick up. So in the end my dealer had to order another transmission! They replaced the transmission as well as the torque converter. Runs like a dream right now as I have only driven it about 20 miles after picking it up from the dealer. We will see...
Old Oct 11, 2018 | 07:05 PM
  #114
dukeh62's Avatar
That is great news, congrats. Please keep us posted on the performance over the coming weeks/months.
Did they mention anything about that being an updated transmission and/or torque converter from what was originally shipping with the car?
Old Oct 11, 2018 | 07:17 PM
  #115
acuraada's Avatar
Good news indeed. This could very well be the reason why Acura hasn't announced a "solution" to a well-known problem: cost. It is probably banking on drivers who don't notice or care enough (like most leasees) to make a case for a new transmission replacement. This goes back to the points made earlier, keep harassing your dealer, don't settle, especially if you going to own the car for a long time.
Old Oct 11, 2018 | 07:18 PM
  #116
code3_rdx's Avatar
8th Gear
You know what is funny is that my wife just finished talking with Acura Customer Care and the guy mentioned that when he talked to the dealer they said the 2nd transmission didn't work and they had to order another one. When we picked up the car, our advisor was on lunch so we haven't had a chance to talk to him. I will find out whether it is an updated transmission or what is going on. Acura Customer Care is working with us to compensate for all the trouble. Will keep you updated.
Old Oct 12, 2018 | 01:08 PM
  #117
DuBignon's Avatar
6th Gear
Appreciate the update, @code3_rdx. Ours started to regress toward the end of week 1 with the new transmission, will be very interested in the outcome of your replacement. Sad to report that we have about 400 miles on the new transmission and are about to return to the dealership to troubleshoot again Strangely, there seem to be better performing days peppered in with the bad, but the overall trend is toward the same concerning state as before.
Old Oct 23, 2018 | 12:11 PM
  #118
trojanshawn's Avatar
4th Gear
I took my car in a few weeks ago for this same issue. After saying they were able to reproduce it, they then started to backpedal and say that other cars were experiencing the same thing and that Acura said nothing came up as "wrong" with their diagnostics.
What have others done to get the dealership to take this issue seriously? I see someone was able to get a new transmission... The harsh jerk is just crazy bad and I'm at 1500 miles.
Old Oct 24, 2018 | 12:05 PM
  #119
DuBignon's Avatar
6th Gear
In my case, the issue was so significant that the tech acknowledged it, did the snapshot procedure for Techline, and Techline eventually recommended a transmission replacement. According to our service notes, the clutch break-in procedure was recommended by Techline first, the tech performed it, but it didn't improve the performance. The transmission replacement recommendation followed.
It should be underscored that the new transmission has *not* remedied the hard shifting, surging, hesitating, etc. with our RDX. As I mentioned in my previous post, the car drove fine for about 4-5 days following the transmission/torque converter replacement and about a month and ~700 miles later has now regressed back to where it was before. We have a follow up service appointment tomorrow and will see if they can remedy the issues. Will post the results here.
Old Oct 24, 2018 | 12:47 PM
  #120
4th Gear
Ugh. That is extremely frustrating that even a new transmission didn't solve the problem? At least you got your dealership to acknowledge it... mine told me verbally they were able to reproduce, but then backtracked on it the next day.
With all of these people experiencing this problem, you would hope that they would be trying to solve for this. Maybe they're just hoping that people don't raise hell about it.
