Dealer or repair facility
Old Mar 10, 2021 | 09:50 AM
Alokin's Avatar
Can anyone recommend a repair facility I can call and discuss my issues which could relay this to a dealer in Michigan? I really need some hep!
Thank you in advance
Old Mar 10, 2021 | 10:03 AM
Well describe the issues going on with your RDX, please!
Old Mar 10, 2021 | 10:13 AM
Alokin's Avatar
Rattles and healiner separation
Justnspace,
thanks for reaching out, I have a rattle coming from IP. It’s coming from the front garnish trim piece that’s closer to the wind shield. Not sure 🤔 if it’s from the garnish rubbing against a-pillar trim pieces. 2nd my healiner has separated from the vehicle and can see these Velcro like blocks separated and don’t won’t to go back in. Plus they are perpendicular to each other vs being parallel. See attached.
Old Mar 16, 2021 | 06:21 PM
JDMaccord3.5's Avatar
Assuming the vehicle still under warranty, definitely take it to the dealer for warranty inspection.\
this is a common issue among RDX owners were moonroof frame seems to rattle a bit
Old Mar 22, 2021 | 12:48 AM
leomio85's Avatar
The rattle you have is from the wind deflector for the sunroof. I completely removed mine.
https://acurazine.com/forums/third-g...lector-988377/
You could also try this:
No idea if that eliminates the rattle or simply deadens it, but removing it will guarantee the rattle going away. I supposed it depends on if you use the sunroof a lot and/or if you mind some more wind noise when the sunroof is open. But, don't fret, there's another creak/rattle/click that comes from the actual frame of the sunroof as well. It isn't nearly as pronounced as the wind deflector though.
As far as the headliner, it looks like those plastic pieces are meant to lock into place after being pushed into one another. Note how they're rounded at the tip but once they push past each other, they're squared off as to lock into place. It looks like a few are marred or ripped out. A good push should pop them back into place. I know I was able to pull down my headliner around the sunroof to peer in when I was getting a buzzy rattle coming from the rectangular speaker-looking box above the driver's seat. The headliner pulled down with a pop but they popped right back into place after I was done.
UW RL
Apr 8, 2007 10:18 PM
F.Rizzo
1G RDX (2007-2012)
Dec 2, 2006 01:05 PM
PRNole47
Jul 20, 2005 04:35 PM
fuzzy02CLS
Apr 19, 2004 10:13 PM
