Center W/S wipers
Old Jan 6, 2020 | 11:21 PM
F1B's Avatar
F1B
4th Gear
Center W/S wipers
Can't follow the procedure in the online Owners Manual (Page 555} to center the blades. Need to in order to clean W/S.
What does the car wash do?
Old Jan 6, 2020 | 11:23 PM
F1B's Avatar
F1B
4th Gear
Should have noted for a 2020 RDX
Old Jan 7, 2020 | 03:23 PM
TheLevelOne's Avatar
-- Instructor --
With the RDX running, you pull the right steering arm up (and hold it up) and then hit the engine off button.
This should center the blades for you.
Regards --------------------
Old Jan 7, 2020 | 06:42 PM
rdxnguyen's Avatar
I was able to center those wiper blades following steps on page 555. It's a bit tricky since the wipers will keep moving and trying to reset to the idle position. Gotta be quick with the power/engine start button. An example of engineering failure on this car
Just putting the manual section here for reference.
Old Jan 8, 2020 | 07:06 AM
Rob175's Avatar
Gosh....bring back the "good o'l days" when all you had to do to change the wipers was........CHANGE THE WIPERS!......no "procedure" required. These designers/engineers need to take their heads out of their butts and realize not everything needs to be a "procedure"!
Old Mar 23, 2020 | 12:53 AM
nncy's Avatar
Don't we all miss the simplicity of the RL where I can simply pull out the arms first into winter mode then change the blades.
Old Mar 25, 2020 | 02:28 PM
Mark S Long Island's Avatar
Try this which someone posted awhile back. I found it easier to follow
Moving Wiper Blades Instructions
With the engine on, PUSH the wiper switch upwards and HOLD,
then press the engine start/stop button and the wipers should
go to the maintenance position after the engine shuts off.
Always lift the DRIVERS SIDE wiper arm first, then the passenger side.
Old Dec 16, 2020 | 06:23 AM
Colin Whooten's Avatar
Has anybody gotten the page 555 directions to work? I just had to start my car for 1 second to flip up wipers for snow 🙄
Old Dec 16, 2020 | 08:39 AM
DriverOne's Avatar
That's what you have to do. If you look at the page 555 directions that someone posted up above, it says that. It's a pain, but there's no other way.
BTW, this may start a huge debate on the forum, but you don't need to lift your wiper blades for snow.
Old Dec 16, 2020 | 09:31 AM
kboo74656's Avatar
Yep I have. It was tricky the first time but now its like breathing. I just do it!
philj
3G RDX DIY & FAQ
20
Mar 14, 2021 03:25 AM
1stRDX?
3G RDX (2019+)
May 13, 2019 08:59 AM
TSX69
May 24, 2012 02:58 PM
rbiggs
1G RDX (2007-2012)
Dec 12, 2010 08:19 PM
