Added OEM Remote Start-Can't Program Remotes
Old Feb 19, 2023 | 11:34 AM
Bearnut's Avatar
4th Gear
A couple weeks ago I installed the remote start receiver in our new to us 2020 RDX. Slam dunk. Took about an hour to install, antennae and power cables right there, plug and play. I have had 2 locksmiths come out to program the remotes. Both completely confident they will be able to do this. Neither was able to program the remotes, saying that they appear to not be transmitting a signal. Unit was purchased from Acura Express Parts online. We put new batteries in the new remotes, the original I replaced was just slightly low, 2.9 volts. No success. First guy only charged $30, second guy $50. I have an appointment at a Honda dealer for next Wednesday but I'm afraid what they are going to charge if they have to screw around for an hour and get no results.
Anyone experience any thing like this? My $320 bargain is up to $400 and counting.
Thanks,
Paul
Old Feb 19, 2023 | 05:45 PM
RDX-Rick's Avatar
So can you confirm that you actually replaced the original fobs with the OEM fobs with the ENGINE start button?
I assume "Programming The Remotes" is just a figure of speech, because it is actually the engine computer that is programmed to accept the new code being sent by the new fob.
Do your original fobs still unlock the doors and start the engine normally (not remotely of course)?. If the programming was done correctly, it "usually involves" first erasing access to the existing fobs and then adding the new fobs, which means the originals would no longer work. NOTE: the procedure varies between brands. Some brands have a table that can hold 4 entries for example, so you could add a couple of new entries without removing the original ones. I don't know what the RDX process is.
Are you saying that you cannot remote start the RDX with the the new fob, or that you cannot unlock the doors and start the engine normally (i.e. touchless) either? If the doors unlocked, it would indicate the programming was successful, and maybe the new receiver was defective or installed incorrectly. I really suspect that the programming was incorrect, since installing the remote receiver should be simply plug and play.
If the touchless entry fails to work, can you unlock the doors using the buttons on the fob?
Does a yellow light appear on the fob when you push a button, and then a red light appears a few seconds later? That would indicate that the signal was transmitted, but an answer was not received from the RDX. If no lights appear at all, it would indicate a defective fob, a dead battery, or the battery was inserted in the wrong direction.
Old Feb 19, 2023 | 06:56 PM
kboo74656's Avatar
Thanks,
Paul
The Acura dealer has to program the new remotes. You will get to keep the original ones in addition to the new ones.
Old Feb 20, 2023 | 04:59 PM
Bearnut's Avatar
4th Gear
Thanks for the reply, Rick. I'm not sure of the process used to do the programming. I was there with the locksmiths, but didn't want to breathe down their necks. A lot of back and forth with the old and new fobs. As for the new fobs, one when lock or engine button is pressed blinks one yellow-three red. The other isn't doing anything. It has a new battery in it. We're dropping it off at a Honda dealer tomorrow afternoon to be worked on Wednesday.
Old Feb 20, 2023 | 05:00 PM
Bearnut's Avatar
4th Gear
Thanks for the reply, kboo. Going to Honda on Wednesday.
Old Mar 25, 2023 | 03:11 AM
KA8coupe's Avatar
7th Gear
Any update?
01bluecls
Mar 18, 2005 12:33 AM
seth30887
Oct 2, 2003 07:48 PM
Inspire
Jun 9, 2002 09:54 PM
MNCLS
Jul 2, 2001 10:38 PM
