Wrapped my Emblem Ring!
I decided to wrap the ring around my emblem, I am not a huge chrome person, I like badges in chrome, but the ring was a bit much in my opinion for the amount of flashy chrome on the front.
So I ordered some 3M G12 2080 vinyl and wrapped the ring, wasn’t difficult at all and I think it looks so sleek now!
Also popping the emblem ring off wasn’t bad at all, just 4 clips in the corners, just have to be careful to not dent or knick the plastic
The following 13 users liked this post by Dereileak:
19 RDX A-Spec (11-13-2022),
bluntman72 (05-20-2020),
Cargramps (05-15-2023),
ChristianRE (04-25-2022),
fogdoctor (03-27-2022),
and 8 others liked this post.
Looks good, nice work! Interesting that your emblem is 2 parts, I think it's 1 piece the ring and the A on most other models. I tried wrapping my front emblem and it's a PITA with the top slot in the A and the inside corners.
yea the actual emblem is behind a protective plastic layer
you will want a thin object, like a plastic pry tool or a strong thin blade, and kinda just work each corner slowly out, I think I did it mostly from the outside part of the ring, not the inside, careful not to knick marks into the plastic, if you do you will want to get them off cause the wrap will have a sharp point under it
DaddyCool (06-15-2020)
'20 RDX Adv, built 11/19
Good stuff! Do you have a wider angle showing more of the car?
19 RDX A-Spec (08-07-2022)
Ge
Agreed, vinyl no doubt nicer, but has to be done by the shop, where as plasti dip I can do it myself...wonder how much they charge for something small like that..
Don't you know it, there are many videos on youtube for how to vinyl wrap emblem
DjZus (08-02-2020)
its very easy to wrap yourself, you will need a heat gun tho. And I recommended removing it, it’s easy 4 tabs In the corners, that way you can get the vinyl behind the emblem and make sure you don’t have any chrome spots show through. Although several have wrapped it without taking it off. I went with 3M G12 2080 vinyl, bought a 1 ft by like 4 ft piece, Enough to wrap it about 5x If mistakes were made, but had no problems
justnspace (06-27-2020)
Pulled the trigger and bought some 3m gloss black wrap today. Was planning on doing just the chrome ring but could i put a sheet over the 'A' also? Would this interfere with the ACC sensors?
Can't believe I've owned this over 3 years and never thought of just wrapping the ring. I have paint and clear that I got way back when, was just too lazy to paint it.
And sadly, I just happen to have a matching piece of film on the shelf. 10 minutes later...
Appreciate the DIY OP.
Time to wash this thing...
Lumify (11-16-2021)
OG
The trim ring has 4 clips at each top and bottom corners.
I used two plastic interior pry tools and wedged one under and slid the other around to the tab and they released. Did that on all 4 corners.
Then I traced the Acura emblem on transfer paper and then added about 1/4 inch to the outline of the emblem and cut my tint to cover just the emblem.
Cleaned the radar lens really good with IPA and then used a heat gun to heat the surface and applied the tint just smoothing it from the middle up and middle down and the shrinking to seal it up.
Scotch bright the chrome really really good and clean with IPA and primer and satin black rattle can paint.
and call it a day.
and call it a day.
No,
and call it a day.
and call it a day.
tsloan71 (04-23-2022)
Quick question for everyone that wrapped their emblem, have you ran into any issues with your radar or sending you error messages? i want to do this as well but i've been told that the radar is very sensitive and has been hesitant because of that
The Beast RDX '19
I've had mine tinted and emblem ring wrapped for almost 2 years now with zero issues. Just don't tint it too dark and you'll be good to go
This piece is simple to wrap if you remove it. How are you trying to apply it? I fee like you should be able to just lay a vinyl on top flat, slit or cut out the middle some, then just use heat and stretch the vinyl down the sides. Trim excess when done. Clear as mud I know LOL
