Turbo Icon
Turbo Gage
Well I have the boost gage on all the time but what is the meaning of the colors? Looking at it as a clock face the color, in various intensity, is purple and from 3 to 6 and red from 12 to 3. I'm sure the red area is positive boos pressure but what is the purple area? It can't be negative boost pressure. It would have been simpler to just show a positive boost pressure number in the circle in my opinion . The dealer did not know when I asked and I don't see an explanation in the quick start guide.
Turbo cars usually have a pressure sensor in the intake manifold to measure boost. When the turbo is spooled up, the intake is under positive boost, shown in red. When you coast or let off the accelerator pedal the throttle plate closes and since the pistons are still attempting to suck air in, you get a vacuum which is shown in purple (the turbo is still producing some level of boost, but on the other side of the throttle plate and excess pressure is relieved by a valve, usually called a blow off valve). Negative boost is equivalent to a vacuum.
I also wish there was an option to show boost as a numeric value (also with the G-meter)
i think I read somewhere that max boost is 20+ Psi. I guess the hondata or other flash will increas from that 14 to closer to the 20..?
Reading some KTuner and Hondata info on the Accord forums, 20 seems to also be the max boost and normal 14 just like the RDX. Same engine basically, the RDX is just tuned for 91, hence the higher hp/tq then the Accord. In the cases of the KTuner Accords, the boost gets turned up to around 17 I believe. Id suspect the RDX applications would see similar results.
Page 135 of Owner’s Manual...
...is not that helpful.
“Turbo Meter
“When the turbo charger is producing boost, this meter shows the boost pressure.”
There is also a drawing of the gauge face with an arc going from 12 o’clock to 3 o’clock, but no mention of colors.
“Turbo Meter
I hope the car is updated so that this meter shows the PSI next to the red and purple graphic. I do like the sport graphics and the "fictitious" G-meter as its called in the manual. It reminds me of the Forza xbox games which I enjoy.
I find both circles useless. I'm not really able to look at either when driving hard enough to create a spike on either. The G meter is impossible to get any meaning - it's not like the RDX can pull 1.3 g's and it seems the outer circle is a full lateral G.
I'd rather have some up/down meter. OR how about a HUD version.
But I'm not going first.
And yes, the gauge is downright silly.
Seems more like an idiot light in reverse
I too was/am not sure what these little indicators mean or do other than they are related to their respective functions. They seem more like video game indicators than useful driver information.
heyitsme
Jan 6, 2006 05:00 PM
