transmission issue
transmission issue
Than engine is cold I put from Park to Reverse I fill transmission try twice to catch Reverse I fill it because rotation is high than engine hot it same only i no fill so much if it normal
If you have 2WD see link below, print it out and take it to the dealer
http://www.urvi.net/forumfiles/SB/B18-062.PDF
For 4WD, use the link below.
http://www.urvi.net/forumfiles/SB/B18-063.PDF
