Splash Guard order help
Old Nov 12, 2018 | 08:35 AM
Coolguy's Avatar
Trying to order accessories from www.acurapartsforless.com (they are cheapest so far) but stuck at splash guard. I see several splash guard in the list (it doesn't show complete set) and not sure which one to select. For example,
Splash Guard, R Rear
Part Number: 75820-TJB-C01
Part Number: 43253-TJB-A00
Now, which one to order? Also, not sure if it comes with all required screws or need to order separate. Can someone help here with all part numbers?
Old Nov 12, 2018 | 12:27 PM
jjacke's Avatar
Amazon Amazon
Old Nov 12, 2018 | 02:33 PM
subin's Avatar
You would need a "set", not single ones.
Part No. 08P00-TJB-200
Old Nov 12, 2018 | 10:13 PM
Boltface's Avatar
I ordered mine from Curry Acura on ebay when ebay had a 10% off day. It came as a set of front and rear along with screws. Also there are two other parts needed for the rear installation which are included.
Edited to add: I didn't keep the packing material so I don't know the part numbers.
Old Nov 14, 2018 | 04:16 PM
Coolguy's Avatar
Thank you everyone..
Old Nov 8, 2019 | 10:14 AM
GW208's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
For those that have installed these guards, did you use the bracket for the rears? I ordered a set of "genuine" OEM 08P00-TJB-200 guards from eBay and it doesn't have the brackets and half the spring clips and screws are missing. The seller says I don't need the brackets but I can't believe the guards would be properly supported with out them.
Old Nov 8, 2019 | 03:43 PM
Boltface's Avatar
I used the brackets. It was almost a year ago but my failing memory thinks the brackets were needed. Like above I ordered from Curry with some kind of discount. I had no left over parts and needed nothing that wasn't included in the kit.
Old Nov 8, 2019 | 05:12 PM
WunderWagen's Avatar
We just did this install on our 2020 RDX... for the rear you need the brackets. It will not install properly without them.
Old Nov 8, 2019 | 06:30 PM
GW208's Avatar
Thank you, that's what I figured and that's what I get for trying to go the cheap route. It looks like I'll be placing an order with Curry.
Old Nov 9, 2019 | 08:25 AM
russianDude's Avatar
How much does Acura dealer charges to install them?
Old Nov 9, 2019 | 08:49 AM
Also, when installing, do you need to remove wheels or jack the car up? I am trying to DIY, dealer is giving ridiculous quotes.
Old Nov 9, 2019 | 11:09 AM
GW208's Avatar
Our dealer charges $145. for the guards or $225. for the guards with installation.
From the instructions it looks like the fronts are easy enough to do but the rears might be easier with the tires removed.
http://www.urvi.net/forumfiles/SB/BII11735-10.PDF
Old Nov 9, 2019 | 02:14 PM
Jimmij's Avatar
I installed both the front and rear. It is easier if you take off the wheels. The front can be done if you turn the wheels but still a pain. Rears I would not try without removing.
Old Nov 9, 2019 | 03:46 PM
Is it because of screws access? I was planing to use angle drill adapter....
Old Nov 10, 2019 | 09:30 AM
subin's Avatar
Yes, removing the wheels would make it easier to align the screws to the holes.
Old Nov 10, 2019 | 01:54 PM
Dereileak's Avatar
If you don’t remove the rear wheels your gonna be kicking yourself with how freaking crappy it will be to install, without the wheels there it’s not bad, fronts can be done without removing them
Old Nov 10, 2019 | 05:32 PM
EFR's Avatar
EFR
Agree. Fronts went on easy but I just took it to the dealer to get the rears on as I did not want to pull the rear wheels which you pretty much have no choice of.
Old Nov 14, 2019 | 10:57 PM
Just install a set, did not need to remove rear wheels with proper tools
Old Nov 18, 2019 | 01:19 PM
Mark S Long Island's Avatar
I installed my OEM over a year ago. the fronts went on easy & fast. I recall the backs being difficult & I could not get the mounting clips on myself. I took it to my mechanic & he installed them in 30 mins at a cost of $60 or so $$$. well worth it..
Old Nov 18, 2019 | 01:42 PM
Rears are easy and dont need to remove tires, just need angle
driver tool for $15 from home depot
Old Nov 18, 2019 | 07:34 PM
Dereileak's Avatar
Or remove the tires for free
Old Nov 30, 2019 | 02:17 PM
GW208's Avatar
I ended up ordering a set of guards from an Acura dealer.
This is the listing for the set I got from eBay, I didn't try installing them but I believe that they will fit. If anyone wants them they are free for pick up in the San Jose area.
https://www.ebay.com/p/9019969673?iid=253946903054
Old Nov 30, 2019 | 02:31 PM
I ordered mine from curry acura as a set. Yes, you do need the bracket for rear
Old Nov 30, 2019 | 02:47 PM
GW208's Avatar
The set from eBay doesn't need the brackets as the rear guards use a molded in piece to take the place of the brackets.
Old Nov 30, 2019 | 07:38 PM
mathnerd88's Avatar
I installed a genuine set from Acura and the ones you have pictures of are definitely not OEM. The rear also comes with a bracket.
Old Nov 30, 2019 | 08:55 PM
GW208's Avatar
I installed a set from Acura also, these are definitely knock offs. I didn't try to install these but just from holding them up against the splash well I think they will fit. I just thought instead of putting them in the recycling bin someone might like to give them a try since I'm offering them for free.
Ynguns2
Sep 19, 2017 11:15 AM
Bruce Banner
Sep 11, 2012 08:21 PM
mallyboi3
Sep 14, 2011 07:37 AM
Neejay
Jun 29, 2010 07:47 AM
Moodist
May 21, 2007 10:07 AM
