Need help installing splash guards !!!
Old Aug 30, 2017 | 12:34 PM
Ynguns2's Avatar
Hello all and good afternoon. I recently purchased a set of 4 Orem Acura TLX splash guards and have a question on how to remove the plastic fasteners which have a small hole in center. I appreciate any feedback as I am not wanting to ruin anything.
Thanks from Jim.
Old Aug 30, 2017 | 01:00 PM
NSXNEXT's Avatar
Front: http://techinfo.honda.com/rjanisis/p...u/BII51875.pdf
Rear: http://techinfo.honda.com/rjanisis/p...u/BII51413.pdf
They look like the typicaly fastener.
Take a flat bladed screwdriver and pry up (gently) the center pin until you can pull the entire clip out.
And moved to correct forum.
Old Sep 19, 2017 | 11:15 AM
rcg851's Avatar
I place splash guards on my TL just the other day no problem what so ever. the new guards should come with every thing you need to install. On my 03 I did not need plastic inserts to fix to fender well. Holes were in place already to screw in place. Rear tires have to be removed if you don't have a right angle drill.
