Need help installing splash guards !!!
Hello all and good afternoon. I recently purchased a set of 4 Orem Acura TLX splash guards and have a question on how to remove the plastic fasteners which have a small hole in center. I appreciate any feedback as I am not wanting to ruin anything.
Thanks from Jim. |
Front: http://techinfo.honda.com/rjanisis/p...u/BII51875.pdf
Rear: http://techinfo.honda.com/rjanisis/p...u/BII51413.pdf They look like the typicaly fastener. Take a flat bladed screwdriver and pry up (gently) the center pin until you can pull the entire clip out. And moved to correct forum. |
I place splash guards on my TL just the other day no problem what so ever. the new guards should come with every thing you need to install. On my 03 I did not need plastic inserts to fix to fender well. Holes were in place already to screw in place. Rear tires have to be removed if you don't have a right angle drill.
