Important Torque Numbers
Here are the official torque numbers for the usual components for you DIY'ers:
- Oil Filter : 12 N-m, 9 Ft-lbs, 108 Inch-lbs
- Oil Drain Plug : 40 N-m, 30 Ft-lbs, 360 Inch-lbs
- Front brake caliper : 50 N-m, 37 Ft-lbs, 444 Inch-lbs
- Rear brake caliper : 25 N-m, 18 Ft-lbs, 216 Inch-lbs
- Wheel Nuts : 108 N-m, 80 Ft-lbs, 960 Inch-lbs
- Transmission Drain & Fill Plugs : 49 N-m, 36 Ft-lbs, 432 Inch-lbs
- Transfer Case Assembly Drain & Fill Plugs : 44 N-m, 32 Ft-lbs, 384 Inch-lbs
- Rear Differential Drain & Fill Plugs : 47 N-m, 35 Ft-lbs, 420 Inch-lbs
- Spark Plugs : 22 N-m, 16 Ft-lbs, 192 Inch-lbs
- Spark Plug Coil Pack : 12 N-m, 9 Ft-lbs, 108 Inch-lbs
Has anyone ever checked the oil filter torque? I think that might be in the DSM-5 diagnostic manual under OCD.
OTOH lubing the gasket before you screw it on is polite. She'll thank you for that.
Michael Hinchey
May 10, 2016 12:58 PM
orgnlprankster7
Apr 23, 2007 01:43 PM
