Changing lug nuts
Old Nov 28, 2019 | 03:28 PM
RedTauren's Avatar
5th Gear
Changing lug nuts
Hello. Just purchased an a-spec and will be changing out the silver lug nuts with black ones/wheel lock. Is it safe to change on lug nut a time...while the wheel is on the car/ground? Also since the a-spec has the 20" wheels, is the torque still at 80? Thank you.
Old Nov 28, 2019 | 05:19 PM
kboo74656's Avatar
Should not be a problem but I would look in the manual and find the torque to verify it after you change them all.
Old Nov 28, 2019 | 07:50 PM
mode360's Avatar
I swapped mine out for black lugs with the car on the ground with no problem. And yes, it is 80ft/lb of torque.
Old Nov 28, 2019 | 11:27 PM
russianDude's Avatar
You can swap them out one at a time, but I would not tighten them to full torque one at a time, just replace one by one and only tighten snug. Then torque them to 80lb-ft in a star pattern going multiple passes
Old Nov 29, 2019 | 07:53 AM
RedTauren's Avatar
5th Gear
Gotcha, thanks guys!
Jae Cross
Sep 11, 2019 03:19 PM
7 Tl
1G TL Tires, Wheels & Suspension
Apr 18, 2011 10:01 PM
92.3cl8
Nov 26, 2008 04:28 PM
Sweeper
Jun 4, 2005 05:17 PM
kaih
Jan 21, 2005 03:32 PM
