Changing lug nuts
Hello. Just purchased an a-spec and will be changing out the silver lug nuts with black ones/wheel lock. Is it safe to change on lug nut a time...while the wheel is on the car/ground? Also since the a-spec has the 20" wheels, is the torque still at 80? Thank you.
Should not be a problem but I would look in the manual and find the torque to verify it after you change them all.
I swapped mine out for black lugs with the car on the ground with no problem. And yes, it is 80ft/lb of torque.
Originally Posted by RedTauren
(Post 16511058)
Gotcha, thanks guys!
