RDX Gauge Pods?
Old Dec 4, 2020 | 12:07 PM
skuzzzzy's Avatar
RDX Gauge Pods?
Hello,
Ive been searching everywhere to find a gauge pod that would fit in my 2019 RDX, but im not finding anything online. Have you guys found anything that works, or know of a place that will create custom ones for not too much money?
I wanted to get a digital speedometer sorta like this one,
https://www.carid.com/intellitronix/...pn-m9250r.html
And mount it here,
I would like for it to look as flush as possible. Speaking to the shop im going to use for the install, they stated this,
"If I were you I would do a search for one that has a mount for A pillars or find a gauge pod for it. The product you linked will need a lot of customization for us to approve how it looks and I believe for you to be happy with it. Cost of the customization and materials would easily be $800. We would need the car for the first day, leave the A pillar here to finish and then come back for us to mount it. All that for just one gauge."
Also, any suggestions on any other digital speedometer gauges that may be as simple/clean as the one I linked but more reliable? Could installing this cause any possible electric issues with the car? I read somewhere a user stated using a hud heads up display caused electrical issues with their car.
Amazon Amazon
"I attempted to install this in my 2017 Dodge Challenger. It was pretty easy to install and seemed easy to use. Looked great on the windshield, HOWEVER, it did make my Check Engine Light come on! I have 10k miles on it and it's serviced by Dodge only and, in fact, was just serviced by Dodge today and the light was definitely not on! I can't use this product if this happens so I will be returning it. Buyer BEWARE!
Update: Went and had my check engine code read and it was U0001 Problem high speed bus/communication control module. This HUD plugged into the OBDII port makes it so my ECU cannot communicate properly with the car."
Old Dec 7, 2020 | 12:36 PM
Funz51's Avatar
Expanse me
Originally Posted by skuzzzzy
Hello,
And mount it here,
https://www.amazon.com/SHEROX-Interf...s%2C210&sr=8-4
I use 'OBD Fusion' OBDII app on my iphone. I have a veepeak OBD module that transmits wifi. works better than the BT ones I think. The OBD Fusion app has a backwards color/font that enables you to put on your dash as a HUD. I have yet to put any time on it. Spend too much time on the sound system/sub for now. But I do use the app, phone attached just below the rearview mirror, and shows a slew of other measurements with multiple screens. Spend a little time setting it up (I can help you with my successful PIDs), and it might fit your bill.
And about that other HUD box mentioned above, that is probably very noisy, causing havoc on the bus.
Old Dec 7, 2020 | 12:47 PM
skuzzzzy's Avatar
Thank you for the response, what do you use for mounting your phone?
Old Dec 7, 2020 | 04:06 PM
Funz51's Avatar
Expanse me
good suction cup and magnetic connection to phone.
something like this:;
Amazon Amazon
William Chang
3G MDX (2014-2020)
Dec 7, 2020 02:48 PM
saxqtzk
1G RDX Problems & Fixes
Oct 10, 2017 07:16 PM
iforyou
Jul 18, 2014 08:15 PM
droebuck
53
Jan 31, 2013 08:54 PM
nippon_wa
Aug 13, 2002 11:26 PM
