Stock Boost Gauge Problem
Old Jul 26, 2017 | 03:57 PM
saxqtzk's Avatar
5th Gear
Hey All,
I have a 2011 RDX and recently the stock boost gauge seems stuck in a single position. I've checked all the vacuum lines and I know it's the gauge that's defective. Does any one know if that piece in the cluster can be swapped out? I only ask because my old '00 Civic Si I could easily swap out the tach, speedometer, etc individually.
Thanks guys
Old Sep 5, 2017 | 11:40 AM
TheWrench116's Avatar
FLETCH
Are you sure it's the gauge? It's not grounded somewhere message Ken he could have a spare
Old Sep 5, 2017 | 12:25 PM
saxqtzk's Avatar
5th Gear
Thanks for the reply. It's definitely the gauge itself. I've had the cluster out and the motor that holds the needle seems stuck. Is Ken a username?
Thanks again
Old Sep 5, 2017 | 12:29 PM
FLETCH
Ken Ben crazy build guy.?.
Old Oct 10, 2017 | 07:16 PM
saxqtzk's Avatar
5th Gear
Update:
I took the entire cluster out and it seems speedometer, fuel, boost and tach are integrated on the same board.
Fortunately, I found the actual motor/gears hidden under a panel and found a tooth or two chewed up. I was able to bend some back and all is working again.
