Potential issues when adding aftermarket sub
Old Mar 16, 2021 | 07:10 AM
Conquistador's Avatar
I'm thinking of having a local shop add an aftermarket powered subwoofer. Nothing big, nothing major, just a sub to add a little more bass. I'm also thinking that with this car (I have the Advanced 2019) there's the potential of them messing something up, like not tapping into the correct line level wires, having issues with the noise cancelling, etc. Am I overthinking this? Should I trust the "pros" will do the right thing? Are there specific questions I should ask them, or other issues I should worry about?
Old Mar 16, 2021 | 07:35 AM
installation is installation. they got that down. a good shop has hundreds if not thousands of installs under their belt. if you're wary about installation, ask them to see some prior installs.. ask them for references.
a good question to ask is "what about ANC? what will you (the shop) do about ANC?"
Old Mar 16, 2021 | 07:49 AM
alright cool. I have a tendency to over analyze things, for better or for worse. I'll inquire about ANC. thanks
Old Mar 16, 2021 | 10:52 AM
Mustachio's Avatar
I think it will depend on the shop/tech, but I will say that I installed my aftermarket sub in one evening without any issues. There's at least one solid guide on here. I never got around to writing one up about my process, but I'm open to answering any questions. FYI - no need to drill through the firewall or into the frame for grounding.
Old Mar 20, 2021 | 11:55 AM
Funz51's Avatar
Expanse me
There are a couple other threads on here discussing the issues with a sub install, including the anc. It is worth the 1/2 read for you.
CocheseUGA
Technology
1673
Jan 28, 2026 03:59 PM
johnnyytruong
61
Oct 31, 2025 12:41 PM
515kbpUA7
Dec 6, 2013 11:29 PM
ckrieg
Oct 27, 2009 03:00 AM
