Infotainment Error - Changing favorite stations
Old Aug 29, 2018 | 09:50 PM
EddieN's Avatar
Exclamation Infotainment Error - Changing favorite stations
Today while driving I selected via the steering wheel button to change the XM Radio station playing to another station in my favorites but instead of changing and displaying the next selected channel the pop up banner in the gage panel displayed the following/similar message: "Error; function not available" I tried several times to change the station both via the steering wheel and the buttons on the dashboard without any luck. Since I was driving I decided to go to the FM Station favorites and as soon as the system switched over I proceeded to change the station via the steering wheel and it worked as it should. I stayed on the FM Radio a few minutes then I switched back to XM and the system returned to normal. Anyone else experience these issues?
3G RDX Tech w/ SH-AWD
Old Aug 30, 2018 | 06:39 AM
gtssenior's Avatar
I have had a few infrequent transient problems with the channel selector on the steering column especially for XM but not at a level of frequency to be re-creatable on demand so I am not going to take it in for service. Most of the time it is just not doing anything when you push the scroll button from side to side attempting to go through your favorites with no error message so I have a different symptom. I don't recall of the forward and backward buttons on the dash not working. I guess I will put my faith in a future software update to correct this and some of the other annoyance type issues.
Old Aug 30, 2018 | 07:12 AM
Madd Dog's Avatar
I have had some issues with no favorites established, and there are favorites on the main screen. Sometimes they come back.
Old Aug 30, 2018 | 08:28 AM
EddieN's Avatar
Good to know that it's not a frequent issue that we are dealing with; if the error happens again I'll take a picture of the error message and start documenting.
Cheers!
Old Aug 30, 2018 | 08:31 AM
EddieN's Avatar
Thanks hopefully these errors go away in a future update; just glad that the system reset by switching the tuner back and forth!
Old Aug 30, 2018 | 08:33 AM
Madd Dog's Avatar
I expect that they are working on the glitches. That is why it is important to make tickets for them to address.
Old Aug 30, 2018 | 10:28 AM
EddieN's Avatar
Done, submitted online ticket! Thaniks!
Old Aug 30, 2018 | 10:42 AM
gtssenior's Avatar
An update on this from observations this morning while running several errands and turning the vehicle off and on a few times....
The left scroll wheel appears to be non functional in terms of selecting channels.for several seconds after the radio has initialized. The backward and forward buttons on the dash appear to be operational right away. Soon the scroll wheel works properly. This behavior seems to be the same for XM and FM. It is as if the path from the scroll wheel to the radio takes longer to initialize than the radio itself. Some people would call this an operational characteristic, some would call it a bug, and some would call it both I suppose. It is not a biggie compared to some of the other issues posted in this forum. When everything appears to be initialized after starting the vehicle, the scroll wheel seems to work fine so far in the limited time I have played around with it in the context of this "issue".
Old Aug 30, 2018 | 10:58 AM
Meto's Avatar
This has been reported numerous times to Acura and my vehicle is the guinea pig to resolve the many issues with the Infotainment system. A system update is coming soon
Old Aug 30, 2018 | 11:05 AM
EddieN's Avatar
Thanks for the info, good to know that these issues may be resolved soon!
Old Nov 20, 2023 | 05:43 PM
rdx4me?'s Avatar
I have this problem from time to time...not specific to XM..I see it on FM, Is there a fix for it? To me it seems to happen soon after startup. I am thinking the system hasn't completely booted up yet???? Anyways it's annoying..the only way to solve from what I can tell is to park, and shut down the vehicle...Restart in a bit...30 seconds or less...I don't think it's a MOST Bus issue? but could be wrong
Any inputs would be appreciated
Old Nov 21, 2023 | 04:06 AM
salgiaco's Avatar
Umpire #27
2022 Aspec Adv. I use my steering wheel to change stations all the time and realize it doesn’t work from time to time - usually just after start up. I found if you manually change the station using the touch pad one time, the scroll wheel on the steering wheel suddenly starts working again? Weird 🤷‍♂️. Minor annoyance but beats shutting car off and turning it back on again
Old Nov 22, 2023 | 12:28 PM
rdx4me?'s Avatar
Good tip...it happened today and this 'reset' worked
Dave48103
Aug 3, 2018 04:03 PM
Moog-Type-S
Mar 2, 2012 02:20 PM
jfdaley
Apr 6, 2009 12:12 PM
Mylriahd
28
Jul 9, 2004 03:50 AM
