Audio distortion
Old Aug 30, 2018 | 11:31 AM
cbstsx09's Avatar
2013 RDX tech Amber
Audio distortion
Has anyone else noticed audio distortion coming from the door speakers when bass is present or when a loud vocal is played. My passenger door speaker sometimes sounds distorted not sure it it is speaker or possibly it is rattling something inside door.
Old Aug 30, 2018 | 07:11 PM
MI-RDX's Avatar
Could be a bad speaker or just a matter of something not tightened down properly - many possibilities. I've not noticed anything of that nature with mine.
Old Aug 31, 2018 | 10:33 AM
cbstsx09's Avatar
2013 RDX tech Amber
I only notice it mainly on strong midrange vocals I can hear distortion. I am going to take to dealer and try to recreate to see if they can isolate and fix it. I got this car for the incredible audio system so I am frustrated.
Old Oct 5, 2018 | 11:53 AM
cbstsx09's Avatar
2013 RDX tech Amber
Have had the car for 7 weeks and had some time to really work the sound system and I think i found the culprit for the strange sound and it is on certain material using the surround sound mode. If I turn off surround sound it goes away. I think that the algorithms for the surround could be creating a strange distorted sound only on certain mixes and frequencies. Since I turned it off the sound is pure and great.
Old Oct 5, 2018 | 08:02 PM
JustAnotherOne's Avatar
Is this specific to 12 speakers or 16 speakers setup?
Old Nov 18, 2018 | 05:59 AM
joeliu2003's Avatar
2022 MDX Advanced
I have noticed this as well.
The “simulated” surround is total garbage.
No subwoofer output and terrible mix mix to all channels.
Old Nov 18, 2018 | 08:43 PM
oblio98's Avatar
WayTooManyAcuras
The DTS Fake Surround in this car really sucks compared to the Dolby Surround feature in the older RDX's. I would suggest leaving it turned off permanently. Unless you have actual 5.1 files to play (which sound amazing), just play the stereo files without the DTS Neural and it will sound fine.
Old Nov 19, 2018 | 11:08 AM
Gate 17's Avatar
My biggest complaint on this car is the audio. I find is harsh and mid-low's are missing. Volumes above 10 are painful. I can localize the music, it is not an immersive experience.
12 speakers, changed setting, tried different mp3's.
My next step is to turn off the ANC.
In reading the TLX & previous RDX forums there are similar complaints with the ELS system.
Old Nov 19, 2018 | 06:47 PM
Njbrandon's Avatar
I turned off the surround sound and increased the roof volume 2 ticks and it sounds much better.
Old Nov 20, 2018 | 12:07 PM
cbstsx09's Avatar
2013 RDX tech Amber
I too tunred off the surround sound and reset to factory settings. I have noticed a noise but I think it is coming from the right side ceiling speaker and it is rattling that corner panel at the sunroof area. All i have to do is put my hand and press up on that corner and the vibrating rattle goes away.
Old Nov 20, 2018 | 12:40 PM
Njbrandon's Avatar
I have a rattle in my headliner by the speaker. When I pressed on it I noticed that the 2 headliner clips are broken and it doesn't pop into place. Every time I hit a bump or just round a corner it rattles. Check your headliner to make sure its popped in.
Old Nov 26, 2018 | 02:01 PM
Dereileak's Avatar
I got a weird rattle sounding speaker today for like 5 minutes, it sounded like the speaker was totally blown in the driver speaker, it was during certain midrange stuff, it then magically stopped doing it. Not really sure why it did this, I was playing it at low volume and it sounded like crap while it was happening.
Old Jan 5, 2019 | 11:28 PM
WhiteRDXAZ's Avatar
No problem on drive home from dealership today, although this was day 1 of ownership.
Old May 17, 2023 | 08:03 PM
Tlxforme's Avatar
Sound distortion
I have the same issue 2015 tlx . I disconnect and reset the the Bluetooth phone and car .works only for a few days then back. Has to be a Bluetooth connection issue with the car. All other Bluetooth I use are fine
shabzinca
Oct 20, 2001 03:08 PM
jz983
Jul 20, 2001 11:06 AM
