Apple Car Play & 2019 RDX
#41
securityguy (05-01-2019)
#42
I was plagued with random carplay disconnects on my commute. On my hour commute, it was typical for my iphone to lose connection to carplay 2-3 times. The 3 finger reboot was only a temporary solution. What worked for me was performing a factory data reset. Settings->System->Factory Data Reset. It was a pain setting up all my radio and sirius presets all over again, but it's been over 2 weeks and I haven't had a single disconnect since.
RDX: D1.1.2
iPhone X: 12.2
Genuine Apple USB cable
RDX: D1.1.2
iPhone X: 12.2
Thanks for the suggestion. It has been working for me since resetting to factory default a couple days ago. This is the first time CarPlay has worked as expected. I have the same setup as you and have had this procedure performed to address the issue shortly after my August purchase date. It didn’t help so I’m guessing this is the first factory reset since the January firmware update. I say I’m guessing because I had the car in the shop in February for this and was told that the system had been rebooted. Apparently that meant something else! Anyway, I hope this lasts because like many others, I am frustrated with CarPlay not working for eight plus months! The slight inconvenience of reprogramming my favorites is of little consequence since I can now use nav apps w/o them dropping out and can listen to podcasts, streaming music, etc. uninterrupted. Thanks again!
Nuf
birdonamission (05-02-2019)
#43
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
When I use Apple CarPlay and either make or receive phone call, during the call the phone randomly gets muted, and people cannot hear me anymore. I can still hear them.
At first I thought it has to do with Waze - when it talks, it mutes the line and never un-mutes. However last time I wasn't using navigation, and it still did it. the only way to resolve it is to switch phone output to speaker or another Bluetooth earpiece and back. really frustrating, especially when it happens while driving. It's downright hazardous.
For now I am driving with Plantronics Bluetooth Earphone.
Has anyone experienced this? Who do I contact? I am sure the dealer would not know what to do. Should I call Acura, or is it Apple's problem?
firstacura19 (07-29-2019)
#44
#45
id rather not do guesses like that considering there's significant time involved in setting everything up again.
#46
All I will say is that everyone that did the reset saw their radio behave 180 degrees from before. Mine is now super fast and trouble free. Highly suggest you try it. All you have to do is reprogram your radio station...not a big deal.
#47
Doesn’t it also reset other clear settings? Like door lock/unlock, paired Bluetooth devices, other driver preference settings?
#50
The infotainment system (CarPlay, SiriusXM, etc.) crapping out was my constant "entertainment" every time I went anywhere with the car...until I did the the factory data reset two weeks ago. Just came back from the Jersey Shore yesterday and it continued to work just fine during the entire 7-day trip to and from, which included a ferry trip across the Delaware Bay, and driving all over the place there. I didn't have a lot of favorites or shortcuts to re-enter but even if I did, no big deal in exchange for the stability and good behavior of the system now.
So no, he isn't just making a "wild guess" about this. This was also mentioned in several thread comments.
securityguy (05-13-2019)
#51
#52
Just wanted to chime in and say that resetting the RDX's entertainment unit and re-pairing my phone via ACP fixed the random disconnects. Very helpful, thank you, everyone.
I will say that the one-way audio problem is still present. Very aggravating. I tried moving to Apple's latest public beta in hopes there was some magic in there but alas, issue persists.
spinedoc777 (05-30-2019)
#55
#56
The disconnects were a constant annoyance for months until we tried the reset, which solved the problem for us. I don't know why our dealer and Acura customer relations weren't able to help us with this (our dealer had supposedly reset EVERYTHING), but thank you to those who took the time to post in this thread!
#57
I'm experiencing the same issue. Factory Data Reset did not solve my issue. I've tried it and the dealer did it (without asking) when they didn't believe me - still have the audio mute issue. Only work-around I've found is to hit the "speaker" button on the phone and then switch it back to car. From that point onward it works. As others have mentioned in this thread, it only seems to happen in the first few minutes of a drive. No issues via bluetooth.
#58
OK I'm going to update because it seems Acura doesn't deserve my anger this time around. After a factory reset the disconnect issue still occurred. Being convinced it was Acura's fault I didn't do anything else and the disconnects got worse. Yesterday I decided to try a different cable and yesterday and today no disconnects, zero. The cable that is at issue is an official Apple cable, but I guess like any other hardware sometimes they fail or have issues. So to anyone else try changing your cable out first to see if that's the culprit.
#59
Be patient and realize that these are made in China or Vietnam and may or may not hold up.
spinedoc777 (06-04-2019)
#60
Interesting, as I have had problems with various Lightning cables over the years. Sometimes the cheapest ones work best, but after sitting in the Arizona heat, they start doing what you described. Maybe the insulation breaks down. I even bought some on Facebook one time, and they stopped working....they are all from China these days. They were guaranteed for a year, so I sent a pic of the dead cables and the supplier sent me like 20 new cables! So, I keep a supply of different lengths and types at home and then swap them out and everything works again.
securityguy (06-08-2019)
#61
Hi everyone,
I was wondering if there are any tips that people are using to try to avoid the infotainment issues regarding carplay after almost a year since the car got released. yesterday was my first time using carplay in the car and the next ignition cycle already gave me a drive mode unavailable message. Thankfully nothing else happened and it resolved itself after the ignition cycle after that.
The things ive done to hopefully avoid carplay infotainment issues is to go into functional setup and turn off andoid auto, waiting for the infotainment to fully bootup before connecting my phone to the car and using a genuine apple cable. Any other helpful tips?
Thanks!
Thanks!
#62
Skeptic
Am I to understand that, in order to use Apple CarPlay, you have to connect your phone using a USB cable? Bluetooth pairing won't do it?
(I have Android phones and, of course, no Android Auto in the car. Hence, my ignorance.)
#65
Anedotally after all of one day of testing (so take with a huge grain of salt) I had zero issue driving around today using the ios13 public beta CarPlay. Also, all of the features worked, which was nice. (Split screen between apple maps and now playing... kind of redundant with the RDX’s split screen, but still nice.) I have had MAJOR problems with the system since I got it in September. Yes, I’ve done all the software updates, yes I’ve done the factory reset. Still have the random freezes, and TONS of skipping. Really crossing my fingers this iOS 13 will fix, but I think its more a problem with Acura’s system than Apples as my iPhone in my wife’s VW has performed without skipping a beat every time I use it.
#66
#67
I just installed the iOS 13 beta and the screen view of CarPlay is different and in my opinion better. Rather than the Now Playing that covered the whole left screen, the new screen contains a more proportional Now Playing screen with other info (I just saw it yesterday on the way home from Bible Study so I haven’t done a screen shot or equivalent yet.
#68
![](https://cimg5.ibsrv.net/gimg/acurazine.com-vbulletin/2000x1504/f84dc2f7_6dd2_4cb6_88e4_35d96f2260b4_db00b6d4c18d1b4196e9db2b126fc8e5c5cfdf42.jpeg)
This is the screen with the new iOS from my phone to the Apple Car Play
markm929 (06-26-2019)
#69
Having just comeback from vacation, where I rented a Chevy Equinox that had CarPlay, I can say without reservation that ACURA is totally to blame for the issues with CarPlay and the Infotainment system. Apple carries no blame on the issues. CarPlay worked flawlessly. I could connect the USB before starting the car or after and no annoying hiccups in sound. I return to my RDX and first connection music starts hiccuping. ACURA programmers are crap and the department needs to be wiped clean and new qualified hires brought in. End of rant.
The following 2 users liked this post by markm929:
asdecorazones (07-15-2019),
Padre Dave (07-16-2019)
#70
Totally agree. My wife's VW Tiguan has worked FLAWLESSLY with my same phone and USB cord. This is completely the fault of the RDX.
I also installed the iOS 13 Beta, and while it worked for two weeks, I got the same beep and freeze last Friday. Had to do the trusty Three Finger Reset AGAIN. sigh.
The following 2 users liked this post by jonarogers:
#71
CJ455
3G RDX (2019+)
93
07-23-2021 11:37 PM
Shane One
15
07-23-2019 08:59 PM
