I meant to bring this up earlier to see if I am missing something. The windshield wipers are placed such that you cannot lift them much away from the windshield without hitting the hood. Normally, when I wash a vehicle, I pull the wipers away from the windshield to be able to wipe and dry it easier. Can't do that with this one.
I tried operating them to move them halfway in a wipe cycle and quickly turning off the ignition hoping they would stop in place. But they do not - they return to the stored position.
It's going to make changing the blades a little more challenging.
Have any of you noticed this, and found a workaround?
Stew4HD
close
- Join DateJun 2008
- LocationSugar Land, TX
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:1,093 Times in 714 Posts
There is a procedure for that...I think I recall it to be: pull the wiper controls arm towards you and then hit the start button with your foot off the brake to work on the wipers...
Thanks. Feeling kind of silly now... I've never heard of that before, but just searched the manual and sure enough, you are correct. Thanks again.
Page 549 of the Maintenance Manual..... It works - it is how I clean the windshield and in the future replace the wipers.
1. Set the power mode to VEHICLE OFF.
2. While holding the wiper switch in the MIST
position, set the power mode to ON, then
to VEHICLE OFF.
u Both wiper arms are set to the
maintenance position as shown in the
image.
3. Lift both wiper arms.
to VEHICLE OFF.
image.
2022 MDX Advanced
Is “mist position” actually pulling the wiper stem towards you to spray the washer fluid?
I tried it multiple times today - no luck.
The wipers are supposed to stop on the windshield - mid-swipe correct?
Quote:
Push the wiper switch UPWARDS and HOLD...then shut off the engine, the wiper would then go into the maintenance position.Originally Posted by joeliu2003
2022 MDX Advanced
Quote:
Thank you!!!Originally Posted by vvlien
Again it’s in the manual ...Originally Posted by cengel
I meant to bring this up earlier to see if I am missing something. The windshield wipers are placed such that you cannot lift them much away from the windshield without hitting the hood. Normally, when I wash a vehicle, I pull the wipers away from the windshield to be able to wipe and dry it easier. Can't do that with this one.I tried operating them to move them halfway in a wipe cycle and quickly turning off the ignition hoping they would stop in place. But they do not - they return to the stored position.
