Transmission fluid check
Old Mar 10, 2020 | 12:52 PM
Vegas RDX's Avatar
Post Transmission fluid check
Anyone found a way to check the oil on the 2019 10 speed transmission on the RDX Aspec yet?
Old Mar 10, 2020 | 06:27 PM
Wander's Avatar
What do you want to check? There is no dipstick for ATF level. If you really want to check the level, there is a plug you would pull on the side of the transmission. But it's unlikely this is necessary before the scheduled ATF change.
Note a metal panel needs to be removed to get access.
Old Mar 10, 2020 | 08:13 PM
russianDude's Avatar
Does anyone know if we have low level ATF sensor that will go off in case there is a leak or etc?
Old Mar 11, 2020 | 12:23 AM
Wander's Avatar
The garage floor is a pretty good sensor for leaks.
Old Mar 11, 2020 | 06:07 AM
Sometimes people have very slow leaks that are not always noticeable on the floor unless you keep checking tranny case for fluid. And also, if for some reason it came from factory with low fluid, you would never know until about 60k miles (that’s about time when MID tells you to change it). Low fluid sensor would be very useful in tranny without dipstick.
Yotrek
3G RDX DIY & FAQ
48
Feb 28, 2024 09:28 PM
RCookman
1G RDX Problems & Fixes
33
May 4, 2020 02:38 PM
jblaze06
Oct 20, 2015 10:38 AM
Crazy Bimmer
Mar 18, 2007 08:23 PM
