So I noticed the other day that the rear outside window trim molding on my aspec is textured while the texture on the
rest of the car is smooth does anyone else have this. To me it just looks off like it was a mistake, it’s on both the driver and passenger rear doors but the front is smooth.
This is the driver side, with the textured on the back door
This is the passenger s side with the texture in the rear door also
new side trim
Also a side not I put on the side molding today, took about an hour and a half, was pretty easy if you follow instructions, I think it looks pretty darn good, I live at an apartment so I’m hoping this saves me from door dings, already have a scratch on the side
Must be a problem on the window trim....mine is smooth all the way around. Like the side molding. I did my own on my Land Rover and it kinda looks like...I did it. Don't know that i want to tackle another but want to get it.
Just checked mine and all 4 doors have an equal bit of texture while the rear window trim is smooth. Not really enough difference to notice unless you were to be looking for it but it is there.
thys even worse cause now it’s not even symmetrical, I would bring that in for sure
I finally had it replaced under warranty today (as I had them check out the brake squeal while in there). So they’re all smooth now, no more mismatched eggshell textured trim.
lucky me when they did mine several weeks ago they left a bunch of scratches on the black rear door trim
