Question about blind spot monitoring
Test drove an aspec today and noticed the BSM is not in the mirrors but in a little box on the inside of the car. Is there a reason why Acura decided to integrate the BSM there as opposed to the mirrors themselves?
pilozm (07-10-2022)
There most probably is but how in the world would we know what it is? Probably money.
I won't pretend to know the motivation for moving the indicator from the mirror to the pillar, but I can think of a few potential benefits:
Moving the indicators closer to the driver would theoretically make them more visible in the driver's periphery.
The black pillar offers a higher level of contrast than the mirror in bright sunlight.
In certain conditions severe glare could wash out mirror-type BLIS indicators altogether.
Damaged mirror assemblies will be less expensive to replace.
A broken or missing mirror wouldn't affect BLIS functionality.
Pillar mounted indicators aren't a distraction to other drivers.
The following 5 users liked this post by HotRodW:
EXCALIBUR1 (07-21-2022),
Ludepower (07-10-2022),
NBPDC505 (07-22-2022),
RDX-Rick (07-10-2022),
tecwerks (07-10-2022)
- Audi has the BSM indicators in the pillar as well. I personally prefer it there as it is indeed in my peripheral view. Embedded in the mirror results in much less contrast. Then again if we drive like we should - and look at mirrors - this shouldn’t be an issue in most scene.
Interesting, guess I see why they would do it that way but it just looks a bit cheap, haha. We have a Subaru Forester that does BSM in pillars, didn’t expect that from Acura
My issue is the indicator Is they don't turn on unless going above 25mph?
I think they should be on at all speeds.
The following 2 users liked this post by Ludepower:
HotRodW (07-11-2022),
Texasrdx21 (07-11-2022)
That's definitely a negative on these cars. The indicators in the mirror are much better (IMO).
JB in AZ (07-23-2022)
Selfish reason but I like when these are on the mirror of cars so that I can see them as the other driver...I trust people so little anymore that if I see I am in another driver's blind spot, I move out of it as quickly as possible if I can.
leomio2.0 (07-22-2022)
The following 2 users liked this post by Gamera:
hand-filer (07-23-2022),
Not sure why people are suggesting it’s a cost-cutting move. It’s just a diode at the end of a wire and the RDX already has cabling running to the mirror for the signal/motor/sensor. So it doesn’t really matter where they place the indicator.
My guess: Their studies showed that it’s safer because when your eyes pan over to the mirror, you’ll see the pillar light a fraction of a second faster than if it were on the side mirror itself.
bluntman72 (07-22-2022)
Unless the cost to manufacture the mirror is higher than the piece of plastic in the door post. Otherwise all things remaining equal, it must’ve come down to a decision based on data.
… an alternative point of view would be they simply pulled it out of their rear end Not unlike many of the things on this car that could’ve been executed better…
Just a thought, but if the indicator came on in say parking lots at 5 mph as you go by a car, one might become numb to their illuminations at other times out on the road because they have been on so often..
