Panoramic Moonroof not sitting flush
Old 02-07-2020 | 05:22 PM
  #41
leomio85's Avatar
Originally Posted by fiatlux
If it makes you feel better, the normal non-pano sunroof on my TLX is also not flush on one side, and flush on the other, so I wouldn't say everything would be fine with a regular sunroof.
Gotta love that Ohioan attention to detail.
I honestly wish it didn't have a sunroof at all.
Old 02-08-2020 | 09:22 PM
  #42
ceb's Avatar
ceb
A sunroof is a great place to put your coffee cup while opening the door without worrying about scratching the paint.
Technically, these aren't a sunroof, they are a moonroof. A sunroof is a movable panel made of metal, while a moonroof is made of glass. That distinction has been lost over the years.
Old 02-09-2020 | 10:41 AM
  #43
russianDude's Avatar
Originally Posted by Gregory Kozlowski
Trust me I understand, and I have no problem with a car going in for a minor fix or two. However, to make my car right its going to require a lot of work. I have a dent in the spoiler from the snapping issue. That requires a new unpainted lift gate which has to be painted by a 3rd party and reinstalled. I need new suspension components to fix the creaking noise which makes the car sound 30 years old - we actually had this issue on another one of our cars several years back - a 20 year old Maxima! I had a new steering wheel put on because the leather was unwrapping. Brakes are a problem - squealing. Moonroof needs adjustment or replacement which either way is major work removing a headliner. This is big stuff we are talking about on a car that I have filled with gas once.
If they have to pull up the gasket, why do they need to remove the entire sunroof? What did dealer do?
Old 02-09-2020 | 12:33 PM
  #44
Please tell us the "fix" that was applied by dealer for a un-aligned gasket.
Old 02-09-2020 | 05:47 PM
  #45
leomio85's Avatar
Also a great place to forget your cup of coffee and watch it pour all over your windshield as it falls.
Coronado111 (02-11-2020)
Old 02-09-2020 | 06:10 PM
  #46
Waetherman's Avatar
2020 RDX White/Espresso
Not sure you're right. As I understand it, the RDX has both a transparent sunroof and a moonroof, the former being the movable 1/2 in the front, the latter being the immovable 1/2 in the rear.
Old 02-09-2020 | 07:28 PM
  #47
ceb's Avatar
ceb
the definitions have become a bit confusing at times and since virtually no car has a sunroof anymore, the term sunroof and moonroof are used interchangeably - but the actual definition is sunroof = metal - moonroof = transparent (glass/plexiglass).
The panoramic roof is a moonroof with second fixed panel. The names came about when Nash built the first sunroof to "let the sunshine in". In the mid-70's, Lincoln designed a "glass tinted sunroof" that they called a moonroof because it made the sun look like the moon. The term caught on and for the next 20 years or so manufacturers made moonroofs. Somewhere along the line somebody started calling those moonroofs sunroofs.
Jointlock
1G RDX (2007-2012)
07-02-2007 01:22 PM
TL_BLUE
11-14-2005 07:12 AM
tommyy2
07-22-2005 10:47 AM
f1fanmarc
04-07-2004 11:30 PM
sc354
12-07-2003 09:12 AM
Quick Reply: Panoramic Moonroof not sitting flush
