Map Update is "live"
Old Nov 28, 2019 | 12:31 PM
  #121
EFR's Avatar
EFR
Just curious if anyone has had any success getting their VIN into the database through Acura or HERE?
Thanks rdxguyen for posting PC guide. I have a Mac, but also have Parallels, so I hope I can get there.....but for that unavailable VIN!!!
Thanks billyt1963 for finding this to begin with. I am still surprised Acura doesn't send out an email, or HERE, or someone, to tell people this is available. If it wasn't for Acurazine I wouldn't even know....but that's true of a lot of stuff on this car I guess.
Old Nov 28, 2019 | 12:52 PM
  #122
Bmosbacker's Avatar
Tech info needed for strong end user but not highly technical
I pick up my new RDX tomorrow (Friday) and I’ll have the dealer make sure the map software is up to date. Nevertheless, I have a technical question for when I need to update the mapping software on my own.
I have a SANDISK 128GB ULTRA DUAL DRIV USB drive that I use for my MBP and my 12.9” iPad Pro. I am running the latest versions of Catalina and iPad OS. As Mac users will know, Apple updated the Mac OS to 64 FAT. The USB works great on both the MBP and the iPad. But given that the thread indicates that the RDX only works with 32 FAT in the USB slot, how do I know how my USB thumb drive is formatted (32 or 64)? And, if it is 64 FAT, how do I reformat my thumb drive to 32 FAT and back again to 64 FAT when I’m done with the update?
Technical help will be appreciated! :-)
Old Nov 28, 2019 | 12:58 PM
  #123
Bmosbacker's Avatar
Originally Posted by rdxnguyen
As promised, I put together a quick step-by-step document (it's a pdf).
Thanks @billyt1963 for the map update heads up and this thread. Thanks everyone for the feedback, and inputs. This is an awesome community!
For those celebrating Thanksgiving (in the States or elsewhere), have a safe and Happy Thanksgiving!!
THANK YOU for putting this together! As a soon be be (tomorrow) RDX owner, this will be a big help!
Old Nov 28, 2019 | 02:05 PM
  #124
Wander's Avatar
By default Mac OS 10.15 uses MacOS_extended with a GUID partition table for internal drives, and I don't think FAT has anything to do with it.
It looks like default for 10.15 disk utility with a 32GB or less USB drive is FAT32 with a Master Boot Record ( MBR ) partition map, but it is a bit coy about it.
I tried a 64GB USB 3.0 USB drive, which was originally FAT32, but disk utility failed to format it with the "FAT" option, and succeeded with EXFAT.
Maybe buying a new cheap 32GB USB drive is the easiest solution. It will almost certainly come formatted as FAT32, MBR. But if you have one lying around somewhere, I think it can still be formatted appropriately with 10.15 disk utility.
Right now, I need to format a turkey, but maybe I'll play more after I'm stuffed.
Happy Thanksgiving!
Old Nov 28, 2019 | 02:23 PM
  #125
Bmosbacker's Avatar
Happy Thanksgiving!
I will be “reformatting” our turkey later today. :-) Thanks for the help! Do you think this will work for map updates?
Amazon Amazon
Old Nov 28, 2019 | 03:07 PM
  #126
Wander's Avatar
I was thinking more like this basic USB A 2.0 drive. You might be at the mercy of the controller for that dual drive, but if you need the USB C connection for your computer, it may be worth a try. Dunno.
Has anyone established whether this infotainment system can take advantage of USB 3.0 or 3.1 speeds? ( Kinda doubt it... )
Amazon Amazon
Old Nov 28, 2019 | 03:30 PM
  #127
Bmosbacker's Avatar
https://www.amazon.com/SanDisk-Cruze...11&s=pc&sr=1-3
To be safe, should I order one with 2.0 and not 3.0+?
Old Nov 28, 2019 | 03:31 PM
  #128
Bmosbacker's Avatar
Never mind, I believe you answered that question in your prior post. :-)
Old Nov 28, 2019 | 05:28 PM
  #129
russianDude's Avatar
I ordered 3.0 32g from amazon, shall see
Old Nov 28, 2019 | 05:47 PM
  #130
Bmosbacker's Avatar
Would you mind sharing what you find out? Thanks.
Old Nov 28, 2019 | 05:52 PM
  #131
yeah, will do, theoretically all USB drives that are 3.0 should be backward compatible
with USB 2.0 ( if thats what Acura standard is), but you never know
Old Nov 28, 2019 | 10:09 PM
  #132
Wander's Avatar
I have a 32GB 3.0 sitting in front of me, with nothing to load onto it.
I think there are two questions:
1) Will the car read the drive?
2) If not, will your computer and OS allow you to format the drive in such a way that the car will read it? This may be a problem for more recent drives and their controllers. Dunno.
Fortunately, these drives are dirt cheap now. Cheaper than a decent oil filter.
Old Nov 28, 2019 | 10:42 PM
  #133
Jerzy's Avatar
My 32GB USB3 drive worked. You need to format it to FAT32. If your VIN is in the database you should have no problem downloading data (download and run downloader first). After that set car to ON/RUN (without starting the car) mode and when is done with booting insert the drive. You will see momentary message "Uploading Navigation Maps". Leave it like that for about 1 hour until you get final message that operation was successful asking to press OK. You are done. I was afraid that USB music will fight for the same port, so I switched to FM radio beforehand. Also, I turned off headlights to prevent battery drain.
Funny thing is, that when I navigated to new address it displayed message "Your map is out of Date". So when my maps were old (original) car didn't complain, but now it has new maps but complains that they are old. Clumsiness of Acura software people is simply amusing.
Old Nov 28, 2019 | 10:57 PM
  #134
Wander's Avatar
Yeah, I was kinda hopeful that this map update would cure that "map out of date" bug in my current installation. Since it appears not, I'm not even all that distressed I can't get it to download. ( VIN issue )
The good news is now I can listen to music ( without skips ) and use Google Maps or Apple Maps in Apple CarPlay. So I'm a little less likely to go full George Costanza on the Interstate.
For that I am thankful...
Old Nov 28, 2019 | 10:58 PM
  #135
skipatrol's Avatar
Originally Posted by Madd Dog
According to the HERE site comment, the upload is VIN specific and supposedly will only work for the VIN that downloaded it.
Yeah I found this out the hard way. Making the VIN match up is just insane. So so stupid.
Old Nov 29, 2019 | 07:07 AM
  #136
Bmosbacker's Avatar
Love " full George Costanza on the Interstate" that! So do the other drivers. :-)
Old Nov 29, 2019 | 09:02 AM
  #137
Bmosbacker's Avatar
i’m picking up my RDX today. How do I make sure that the HERE site has my VIN number?
Old Nov 29, 2019 | 09:11 AM
  #138
rdxnguyen's Avatar
The newest Map version is 2019.07.08, chances are the dealership has it updated already. You have the VIN by chance? Punch it in on the site (I had some quick instructions here), and see if it recognizes the VIN. Or just ask the dealership to check it out for you.
Old Nov 29, 2019 | 09:49 AM
  #139
Bmosbacker's Avatar
Thanks for the help. I don’t have the VIN yet but I’ll try your suggestion once I have it if the dealer has not updated the software. Thanks again!
Old Nov 29, 2019 | 10:03 AM
  #140
Madd Dog's Avatar
I expect it is not updated. Butnyou can press them to verify that the VIN is in the appropriate databases. Tell them you have become aware that some people couldn’t get updates because their VINs were not in Acura’s database or the map distributors database.
Old Nov 29, 2019 | 10:29 AM
  #141
konyo1's Avatar
Is the update not available to Canadians? I entered my VIN # on the acura website and it says it can't find it.
Old Nov 29, 2019 | 12:19 PM
  #142
Wander's Avatar
Sacrifice a goat?
Old Nov 29, 2019 | 12:20 PM
  #143
gtssenior's Avatar
I did manage to get the map updated to 2019.07.08, but the elapsed time was about 5 hours with a few stumbles along the way and I did not even have a problem with the VIN being recognized. Most of the people here are fairly technical and will get through it once their VIN is in the database and they have the right flash drive formatted correctly. But there is a whole population of owners that would be like a deer in the headlights if they wanted to update their navigation maps. Dealers should hire a couple college or high school IT minded persons to do this work part time at the dealer. An owner makes the appointment, the dealer already has the VIN, they do the download to a flash drive ahead of time and when the owner arrives it will only take an hour to do the map update, This done at fairly minimum cost to the dealer and is free to the customer and written off as customer good will.. A happy customer is a good thing for a dealer.
Old Nov 29, 2019 | 12:28 PM
  #144
Royki5cp's Avatar
I'm getting the same message. I called the number for contact us, and that is no help at all. Just a series of options and no one to talk to
Old Nov 29, 2019 | 12:50 PM
  #145
Wander's Avatar
Old Nov 29, 2019 | 02:11 PM
  #146
Royki5cp's Avatar
Thumbs up Number t call?
What is the best number to call to get your vin into the database?
Old Nov 29, 2019 | 02:33 PM
  #147
Bmosbacker's Avatar
I pick up the car in an hour. The dealership assured me: “I will definitely make sure that your software is up to date. As for Acuralink I will be setting that up for you and it should be working before you leave.”
Old Nov 29, 2019 | 03:03 PM
  #148
97ws6's Avatar
1 (888) 549-3798 option 1. I spoke with Lauren she knows about the database issue.
Old Nov 29, 2019 | 03:07 PM
  #149
Royki5cp's Avatar
Thank you so much! I really appreciate it! I’m sure I will have to wait until Monday morning.
Old Nov 29, 2019 | 03:27 PM
  #150
97ws6's Avatar
They're open 9-7 EST
Old Nov 29, 2019 | 03:41 PM
  #151
ToniRDX19's Avatar
I am on the phone now calling the same number and option 1. The person I am talking to has no idea. She said there is no updates for 2019 RDX which is nonsense. She’s putting me on hold while she check with another department. So frustrating...
So what was the resolution for you? The lady I spoke with is clueless. She tells me to call the dealer where I purchase the vehicle.
I just called the dealer service department (Schaller Acura, Manchester, CT) they have no clue. The lady told me they did the update last week. I corrected her They did not because I checked my Map version 2018.02.16 then told her I went in for soft brake TSB and squealing. Then she said dealer update my infotainment which I then said she was incorrect because I did the OTA myself. She then switch the subject back to map update and said I have to buy a DVD. What a waste of time!!!
Old Nov 29, 2019 | 03:46 PM
  #152
Royki5cp's Avatar
Let us know if you have any success?
Old Nov 29, 2019 | 03:57 PM
  #153
pnoi521's Avatar
Registered TL Owner
FWIW I clicked on one of the HERE links posted on Acurazine and got the VIN error message. When I went through a different link from google I was able to download the update using my VIN. For those of you that are receiving the VIN error it might be worth it to try this link. I haven't read through the thread so I'm not sure if the correct link has been posted previously.
Old Nov 29, 2019 | 04:35 PM
  #154
skipatrol's Avatar
I called and spoke to Lauren directly and she said she cannot fix this problem and to call Acura. I called the number she have me and they say my VIN is in their database already. So sick of the run around. I don't know if you got a different Lauren but mine was no help at all.
Old Nov 29, 2019 | 04:48 PM
  #155
Wander's Avatar
That seems to take me to the same site and the same VIN issue.
Old Nov 29, 2019 | 05:01 PM
  #156
Royki5cp's Avatar
I called customer support and they said they saw no update for the 2019 RDX maps. They said tech support would not be available before Monday, due to the holidays.
Old Nov 29, 2019 | 05:36 PM
  #157
JB in AZ's Avatar
Just an off the cuff comment:
It seems to me, that there has NOT been any official Acura or HERE (or what ever) notification that there is an update.... RIGHT?
AND reports of "map out of date" messages.....
I don't need the stress of trying to get an update, and getting associated error messages, as I am very happy now that we have AA and Google maps. I'll use that for the time being, and see where all this goes.
Thank you all who are trying ti update it and posting steps, and links, and details of your efforts.......etc.
Old Nov 29, 2019 | 07:10 PM
  #158
kboo74656's Avatar
Same error message.
Old Nov 29, 2019 | 07:45 PM
  #159
Wander's Avatar
The past two map updates were pulled within days after they appeared.
The major "benefit" of installing one of those attempts is the "maps out of date" message every time you calculate a route, and sadly that doesn't seem to have changed for this one. I kinda thought the D.1.2.1 infotainment system update might take care of that, maybe along with future map updates. Guess not.
Which is to say there may be value in waiting if your system isn't already messed up by a prior map update. Or even if it is.
Old Nov 29, 2019 | 08:56 PM
  #160
dpg's Avatar
dpg
I'm from Canada and my VIN worked. Downloading as we speak.says 16 hours...wow. Guess I'm keeping the computer on all night. Wouldn't be surprised if it times out before then...lol
