Map Update is "live"
Old Dec 18, 2019 | 07:24 PM
  #401
NooYawkuh's Avatar
Skeptic
When installing software, I almost always accept the default location. I'm surprised it worked from the USB, as that should not be in the command search path. Just seems like vulnerability.
Old Dec 18, 2019 | 07:32 PM
  #402
arjaykay's Avatar
I received a call from Laura at HERE today and she had me check if "Connecterd Features" was enabled under "Navigation". It was. Once I confirmed that, I was able to access the Navigation Maps download on my computer. Finally, after three weeks. I downloaded the map update and installed it without a problem. I was able to install the update in "Accessory Mode", which others seemed to have a problem doing. I now have the 2019.07.08 version of the maps.
Old Dec 18, 2019 | 08:47 PM
  #403
Mikeg040's Avatar
How long did it take to install the update? Not counting the download.
Old Dec 19, 2019 | 06:24 AM
  #404
mcpagano's Avatar
The install in the car took about 50 minutes
Old Dec 19, 2019 | 08:19 AM
  #405
markm929's Avatar
Called in my VIN (twice): ,
Connected Features enabled:
Still waiting 3+ weeks later:
Old Dec 19, 2019 | 03:57 PM
  #406
97ws6's Avatar
Same. I disabled and re-enabled features just to see if it will work.
Old Dec 19, 2019 | 04:19 PM
  #407
97ws6's Avatar
This worked!
Start the car
Start navigation, go to the menu and if Features is already enable disable it for about 20 seconds and then re-enable it. It took maybe 5 minutes for HERE to recognize my vehicle.
Downloading the update now.
Old Dec 19, 2019 | 05:28 PM
  #408
mcpagano's Avatar
This worked!
Start the car
That was a good idea!
Old Dec 19, 2019 | 05:29 PM
  #409
Wander's Avatar
Well, after I finally got the map update applied, my built-in Nav is twice as good as before. While routing, it repeats every road name twice.
Old Dec 20, 2019 | 11:13 AM
  #410
platocplx's Avatar
Got this updated, Biggest issue I had was the USB and if you do have a greater than 32 gig USB you can still use it.
If you go to disk management in windows, go to the USB drive, Delete all Volumes, format, then you Partition the drive into one being over 32 gigs and leave the other side unpartitioned. then it should work. also if not mentioned the updating maps message doesn't persist just pops up once I was confused by that for a while but I drove an hour today and it updated that whole time after only showing once.
Old Dec 20, 2019 | 01:19 PM
  #411
ToniRDX19's Avatar
This worked!
Start the car
This method worked for me but without starting the car. Double-press the start button without stepping on the brake. Go into Navigation and disabled connected features. Wait 20-30 seconds and then re-enable. Plug in USB 2.0 formatted as FAT32, primary partition and downloaded maps. A message pop-up indicating updating map. The pop-up is very short maybe 3 seconds so keep an eye out. My navigation is updating now. As an IT guy Acura is making this process such as PITA. There could be a bug in the connected features. I spent the last two days trying to get the NAV to update unsuccessfully. I did everything right and went out to buy two new USB sticks. Download the maps multiple times thinking the maps were corrupted.
Old Dec 20, 2019 | 05:17 PM
  #412
EFR's Avatar
EFR
So close, yet so far.
So the unbelievable happened...my VIN finally worked in the acuranavi webite...AKA HERE.
Took my new 32GB SanDisk Ultra 3.0 USB....and downloaded away. After about 40 Min it was done.
Placed the USB in the Acura after the two push without brake pedal mode. A brief message popped up about the download and went back to the car about an hour later. Info screen said download comlete. Removed stick, started car and drove around the block.
Got home, turned off car, restarted it and went to map version under menu in the navi screen and....version 2018.07.18 or whatever it already was. NOOOO! The HERE site said this "Latest map database version available: 2019.07.08" and that's what I clicked 'download' on.
Dear smart people...Where oh where did I go wrong?
Old Dec 20, 2019 | 05:23 PM
  #413
mcpagano's Avatar
I think you are OK. Same thing happened to me. I had to restart my car about 3-4 times and then it said the correct date. I think as long as you got the message that the map update was done, it should eventually show the correct date.
Old Dec 20, 2019 | 05:48 PM
  #414
EFR's Avatar
EFR
courtesy of Inglourious Basterds...Oooh, that's a bingo! .
Thanks mcpagno...that is apparently what it needed-a few engine starts. Now it's on the 2019 version. And what's different? No idea, but I tend to be anal about software updates, so I can cross that off my OCD'ish list.
Old Dec 21, 2019 | 02:54 PM
  #415
beancount1's Avatar
Decided to take the plunge. No problem downloading the map update from the website to the flashdrive, but when I place the flashdrive into the car usb port the flashdrive flashes like it's doing something, but nothing comes up on in the navigation showing that it's downloading. Is it supposed to tell me it's downloading?
Old Dec 21, 2019 | 03:09 PM
  #416
NooYawkuh's Avatar
Skeptic
No. Just leave it be for about an hour.
Old Dec 21, 2019 | 03:16 PM
  #417
EFR's Avatar
EFR
I would also add, I think you need to push the start button twice (without foot on brake pedal). I initially did it with one push and nothing happened. But when you push it twice there is a brief message that pops up on the infotainment screen about it downloading and it is gone in about 2 seconds. After that the next thing you see is 'download complete' up to an hour later. There is no ongoing download status on the screen. As I noted earlier when I went to check my map version after completion it still showed the old one that was already in it...and as someone pointed out and for whatever reason, it took about about 3 or 4 restarts of the engine to get the map version to show the correct and current one.
Old Dec 21, 2019 | 03:33 PM
  #418
Madd Dog's Avatar
Each time you start the nav screen, it should briefly say it is Updating. I basically sat there, watched the thumb drive flash for nearly an hour, listening to music and bouncing between screens, seeing the ‘updating’ one each time I reented the nav screen; it said ‘updating’ until it did.
After a time or two, my ‘maps out of date’ screen stopped appearing. Today, wonder of wonders, it gave me good directions that avoided some traffic.
I am headed down to Florida next weekend, and while I will rely on Google Maps and Waze to get me over the tough spots, I will let this nav run for a bit in the easy sections.
Old Dec 21, 2019 | 04:39 PM
  #419
platocplx's Avatar
Like others said no other indication. You can even drive around with it and it will update then pop up after about an hour.
Old Dec 22, 2019 | 07:20 AM
  #420
DrWoo's Avatar
Just a FYI in case someone else has this happen, I did the map update on Wednesday, verified the version, but did not open the nav. Thursday, I started a 100 mile trip using Apple Maps, and noticed that the speed limit was not showing in the dash or HUD. As I got close to my destination, I switched to the car nav, and the speed limit reappeared. Switched back to Apple Maps, and all was good, and worked fine on return trip yesterday.
Old Dec 23, 2019 | 09:17 AM
  #421
beancount1's Avatar
No luck. I downloaded the files to a new 32 gig fat formated flashdrive. Went out to the car, pressed the start button twice, inserted the drive, the flashdrive red light began flashing slowly. Nothing came up on the screen even for a second showing the downloading began. But I left it in for 2 1/2 hours hoping not to discharge the battery too much. No indication that downloading was complete. Checked the map date and still the old 2/16/18 date. Doesn't seem that the nav is recognizing the flashdrive. Any thoughts would be appreciated.
Old Dec 23, 2019 | 09:32 AM
  #422
Funz51's Avatar
Expanse me
ok, when you plugged your usb in, did the nav say something on the screen? A note will come up saying it saw the drive and it is updating. Apparently the nav always looks at the files on the drive, and if it recognizes the map update files, it automatically goes into 'update mode'. and , it is supposed to continue loading even if you turn the car off and back on again. there are comments above that state the opposite, but that is the official instructions.
Old Dec 23, 2019 | 09:39 AM
  #423
beancount1's Avatar
Nothing comes up saying the drive is updating. I know that usb port (next to cupholders) works because the flashdrive lit and I've attached my iphone at times and the infotainment system recognizes it for carplay. I'm wondering if I should start from scratch and erase the flashdrive and redownload the files.
Old Dec 23, 2019 | 10:16 AM
  #424
gtssenior's Avatar
The flash drive is probably ok if the download worked successfully to it. If you start the car, have the flash drive inserted and then push the on/off button to stop the car and then open the door, it removes power to the USB port. If you push the on/off button with your foot off the brake after stopping the car, and open the door, power remains to the flash drive's USB port. The documentation is pretty weak in explaining this. You could have had a sequence problem on this, causing the installation to abort when power goes off to the USB port. If it does install, you will get a popup message that the map update is finished and that takes in the range of 50-60 minutes.
Old Dec 23, 2019 | 10:33 AM
  #425
beancount1's Avatar
OK, I went through that sequence. I'll give it an hour, though nothing popped up indicating recognition.
Old Dec 23, 2019 | 10:39 AM
  #426
Mikeg040's Avatar
When I put he USB drive in it the message I saw was it found he maps on the drive then you don't see anything (took a few seconds for it to find the update on the drive). It installs in the background with no message but if you click menu on the navi screen then hit back to get to the map it shows for a few seconds map is updating then message goes away. That is the way i was checking it was updating. It took about 50 minutes then you will get a message when it is done that states map has been updated.
Old Dec 23, 2019 | 03:01 PM
  #427
Madd Dog's Avatar
Someone else here had a similar problem. IIRC his last use was to play music via USB, so maybe the car is looking for music? Change your music source to FM, and leave that on and try again.
Old Dec 23, 2019 | 03:18 PM
  #428
beancount1's Avatar
I finally got it to update. I redid the map download to the flashdrive. Although all the files appeared on the drive when I originally updated it only took about 20 minutes to complete. I thought that was strange when everyone else was saying 2 hours or so. I erased and reformated the flashdrive and it downloaded over about 2 hours. Then I went to the car, hit the start button twice (without foot on brake) and inserted the flashdrive. Sure enough in about 30 seconds a message popped up indicating that the map was updating. About 50 minutes later another message that it was complete. The directions supplied by acura for this download are atrocious. I thank all that tried to help me.
Old Dec 31, 2019 | 08:04 AM
  #429
R. White's Avatar
Real pain
Took 7 hours to download the file with multiple crashes and disconnects. Fairly high speed wifi.
Plugged the drive into the car overnight. Didn't finish I guess. Thumb drive is still blinking. The old version shows on nav. I'll try the connect function later.
Old Dec 31, 2019 | 09:18 AM
  #430
Waetherman's Avatar
2020 RDX White/Espresso
Your car has to be on for the map to update. I’m assuming you didn’t leave your car on overnight. Try again the next time you’re driving around - the map update happens in the background so you can still use other functions on infotainment.
Old Dec 31, 2019 | 10:43 AM
  #431
gtssenior's Avatar
My download took about two hours with the following environment:
PC with flash drive was ethernet connected to router (no Wifi involved)
25 mbps downlink with throughput validated using a couple different internet speed tests prior to download.
No VPN activated.
No videos being watched or interactive games being run elsewhere in the house over the internet connection when the download was occurring.
Didn't know how busy the code server at HERE or wherever it is when I downloaded which could also be a bottleneck..
Old Dec 31, 2019 | 02:20 PM
  #432
itsardx's Avatar
'20 RDX Elite
It took me about 2-3 hours to download in a Win10 PC, connected via Ethernet. Maybe try the download later at night or early morning might be faster. Make sure the PC doesn’t power down, switch off hard disks etc (Power settings), if you leave it alone for a while.
If it did not work in the car, I would format the USB stick again and download from scratch. Use the full format (not quick) option just to be sure (takes more time).
I used a 16GB USB stick, but use a 32Gb if you have one. I installed the download manager software on to the PC. Mine was a USB 3.0 compatible one (blue colour connector), but do not think this is required as I read somewhere the port is not USB 3.0.
In the car I clicked the start button twice then inserted the USB drive once the display was up. The update should pop up on the display once the USB is detected. I might have gone to the Navi screen to get it going (be in Navi screen then insert USB). I turned off all other radio functions before hand. Once I saw updating on the screen, I exited the vehicle and went on to do other stuff, checking once a while and at some point it said completed or something(about 40mts). I got into car, switched off car, opened and closed the door, waited a few sec and did start button push 2 times. Verified map version, it looked good and that was it.
If it still doesn’t work, try another USB drive, if you have used the USB stick a lot, it might have bad sectors and all, ideally a full format should take care of it, but...
Old Dec 31, 2019 | 03:36 PM
  #433
wmkim's Avatar
The map download client they make you use is crap I think. It kept failing (saying there was no internet, etc.) on my Mac; I fired up Windows, and it was slow (though not 7 hours), but it finally finished.
I then let it update (I think it was like 40 - 50 minutes) while I was driving around running some errands. A message popped up that said the map update was complete and the restart the car to activate the new version. All in all, a very tedious process for sure...
Old Jan 1, 2020 | 07:41 AM
  #434
R. White's Avatar
The instructions say the car does not have to be on - obviously wrong. I will try driving around today to see if it will finish.
Tesla could do this over the air six years ago. Acura and others better catch up fast.
Old Jan 1, 2020 | 08:25 AM
  #435
kboo74656's Avatar
I did the update and and the car must be on or in accessory mode to do the update. Those are the only ways you can perform it.
Old Jan 1, 2020 | 09:29 AM
  #436
mcpagano's Avatar
It will also work without running the car. Just press the Start button twice without touching the brake. Turn off your lights and the radio so the battery doesn't wear down.
Old Jan 1, 2020 | 09:30 AM
  #437
russianDude's Avatar
wow, this thread is still going on. I updated my map like a month ago, verified its the latest version, but have not used it, still using waze.
Old Jan 1, 2020 | 11:50 AM
  #438
BerwynBill's Avatar
I think the confusion that's been prevalent through this whole process has contributed a great deal to that.
Mine's all done. For reference here's what i did:
- Made sure VIN is active in HERE system. This took multiple emails but finally worked. Also made sure the Connected Services in the Navigation app menu was Enabled.
- I used a PNY 16gb drive I had laying around and a free formatting app to format it to FAT32 (Softionic's free Formatting for Windows).
- I installed the Downloader App from HERE and followed the prompts to find the formatted USB drive.
- Downloaded Map Update. Mine took about 40 minutes on a 155Mbps wifi connection.
- Inserted the USB drive into the socket in the cupholder compartment of the RDX and pressed Start twice without foot on gas.
- After the head unit finished booting, I opend the Nav app & I got a message saying Maps were being updated. I left the car like that, not running.
- At around 45 minutes, I noticed a message saying the update was successful and to restart the car.
- I switched off the power to the accessories and then started the care as usual. I went to the Nav app and checked the version and it was the 2019.07.08 version.
Your mileage may vary and contents may settle during shipping. Colors may not be exactly as pictured and not every ticket is a winner.
Old Jan 1, 2020 | 02:04 PM
  #439
mcpagano's Avatar
You had one typo. It is without foot on the brake not the gas. "- Inserted the USB drive into the socket in the cupholder compartment of the RDX and pressed Start twice without foot on gas."
Old Jan 1, 2020 | 03:14 PM
  #440
BerwynBill's Avatar
Good catch, thanks! Those who know me know I don't have my foot on the brake very often. lol.
