Homelink universal transceiver problem
Old Nov 30, 2018 | 12:01 AM
mechonit's Avatar
Did anybody had problems with homelink universal transceiver? My system suddenly failed, first by opening the garage door only partially, then by stopping working completely. All my attempts of restarting and reprogramming homelink buttons didn’t succed, no any light flicking, no any button becoming active. Any experiences to share? Thanks.
Old Nov 30, 2018 | 07:36 AM
MI-RDX's Avatar
Does the opener work with other transmitters?
Old Nov 30, 2018 | 08:10 AM
Midwestuser1's Avatar
Did you happen to put LED light bulbs in your garage or garage opener? I did that years ago and it caused all kinds of interference with the garage openers from working correctly. Just another thing to cross off the list.
Old Nov 30, 2018 | 10:27 AM
DHood's Avatar
I put special LED Bulbs in the opener. Genie sells them specifcally for GDO and I have not had a problem with using them.
DavidH
Old Nov 30, 2018 | 10:57 AM
mechonit's Avatar
Yes, it works fine with the GLA 250 and the handheld remote.
Old Nov 30, 2018 | 11:01 AM
mechonit's Avatar
That’s interesting. Yes, we’ve recently put the LED bulb in the dining room within a short distance from the garage door. I’ll disable it and see if anything changes, Thanks!
Old Nov 30, 2018 | 11:50 AM
Tom2's Avatar
Unregistered Member
DavidH
Yes, many of the early LED bulbs caused interference with the signal from the remote to the opener. It seems that quite a few of the latest LED bulbs don't cause that issue anymore. I got some from Home Depot and they work just fine in my openers.
Old Nov 30, 2018 | 11:54 AM
If the standard remotes still work fine then the issue points to the Homelink in the car.
Old Dec 2, 2018 | 08:16 PM
mechonit's Avatar
I managed to revive the Homelink Transceiver. The secret appeared to be in bringing back the orange control light. Once you get it, the rest is by the book. It emerged almost by accident through my numerous attempts of repositioning the car in front of the garage. The cause of sudden homelink loss remains unclear.
Old Dec 2, 2018 | 08:31 PM
Madd Dog's Avatar
IIRC, touching and holding two buttons clears something.
Old Dec 3, 2018 | 09:53 AM
Coolguy's Avatar
oh .. that reminds me to setup one ,, .i will set it up and post the feedback.
Old Dec 4, 2018 | 01:42 PM
SWF's Avatar
SWF
Homelink in the RDX works better than it did in my GLC300. Not one single issue so far.
Old Dec 4, 2018 | 02:10 PM
securityguy's Avatar
Yes...if you hold down the two outside buttons for about 30 seconds, it clears and resets the Homelink in the car.
Old Dec 4, 2018 | 02:17 PM
MI-RDX's Avatar
Same here, except I don't have the GLC. Works better than my last 2 vehicles. If there's nothing in the way blocking signals (like a tall truck/van) it will open my garage from about a block away.
Old Dec 5, 2018 | 11:36 PM
mechonit's Avatar
Madd Dog-I am not sure if that's the case, but an accidental holding of two buttons at once might've been the cause. The leftmost button under our mirror is somewhat rigid, which could've caused me touching the next neighbor, and basically hitting the two together.
Old Dec 5, 2018 | 11:46 PM
mechonit's Avatar
I see, thanks. That makes my theory of two buttons pushed at ones by accident (an earlier response to Madd Dog's good comment) , basically obsolete .
TerpNation
Sep 23, 2012 01:50 PM
stever627
Jan 8, 2007 09:47 AM
juanjo
Sep 19, 2006 09:42 PM
AsianRage
Mar 3, 2005 10:43 AM
axle209
Aug 10, 2004 10:19 AM
