Found rubber gaskets in trunk - new 2020 rdx
Old Jan 7, 2020 | 08:36 PM
Gregory Kozlowski's Avatar
Found these rubber gaskets in the trunk of my 2020 RDX..anyone know what these are used for? Thanks!
Old Jan 8, 2020 | 05:22 AM
kboo74656's Avatar
Body plugs under for under the vehicle. Keep those.
Old Jan 8, 2020 | 05:58 AM
russianDude's Avatar
Body plugs that go under the car, your dealer forgot to install them, I would go back and question them if they performed full TQI inspection as they are supposed to. They are getting lazy, they must perform TQI before car is sold.
Old Jan 8, 2020 | 08:06 AM
Waetherman's Avatar
2020 RDX White/Espresso
That's what the body plugs look like? They don't look like they would snap into place....
I have yet to check my car to see if it has body plugs installed. I suspect the dealer did not install them. My dealer doesn't have a great reputation with me for attention to detail, ever since I found a banana peel in my engine bay.
Old Jan 8, 2020 | 09:27 AM
I will ask the dealership to have a look today. Unfortunately I have to bring my car in already for the lift gate snapping noise. The middle of the lift gate is creased/dented and the edge is very rough where it’s making some contact. I’m extremely disappointed having owned this car for 1 week. This quality is unacceptable on a vehicle that MSRP’s at 47k
Old Jan 8, 2020 | 11:46 AM
kboo74656's Avatar
Your trunk latch needs adjusting and maybe one of the struts also. Same thing happened on mine and those adjustments solved it.
Old Jan 8, 2020 | 12:31 PM
you mentioned struts..did you have an issue with your front strut? My driver side front strut/shock is clicking and squeaking over every bump
Old Jan 8, 2020 | 01:51 PM
kboo74656's Avatar
I am referring to the struts that lift the rear hatch lid.
Old Jan 9, 2020 | 07:50 AM
BoBoish's Avatar
I'm one of those that actually bought a couple of these body plugs since they weren't put in. I thought we only needed two (right between front and rear doors), but he's showing five. Are there other spots they should be installed?
Old Jan 9, 2020 | 07:54 AM
The bigger concern if dealer was lazy and skipped other TQI checks listed in the instructions.
Old Jan 9, 2020 | 09:39 AM
Blu2's Avatar
Can someone link to the TQI document?
Im curious if mine were properly installed since my dealership was pretty rushed in delivering the vehicle to me. I know this because the headlights needed adjustment for being too high which should have been adjusted during the TQI.
Old Jan 10, 2020 | 01:48 PM
jc411's Avatar
Does anyone have info on exactly where the body plugs go so I can check if mine were installed? I ask because I found a small ziplock bag in my new car with similar looking parts.
Old Jan 10, 2020 | 01:59 PM
flames9's Avatar
here: https://acurazine.com/forums/third-g...-noise-973469/
Old Jan 13, 2020 | 08:46 PM
I am very confused with these body plugs. I had 5 loose ones in the trunk and found two more today in a sealed plastic bag in the glove box for a total of 7. Also found the small circular cap that goes under the hood where the latch mechanism is..will attach that photo. I looked at the other threads, some say only two holes should be plugged, the TQI PDF looks like 4 plugs should be installed..but under the car there are 7 holes available. 3 along each side and 1 where the spare tire would be (if you have an A-Spec without a spare). We gotta get to the bottom of this to make sure they are in the right place. Cant have water getting in or not being able to drain properly.
Old Jan 14, 2020 | 09:50 AM
jc411's Avatar
While we're on the topic of things left in the car, I also had a bag of four screws. Does anyone know what these are for?
Old Jan 14, 2020 | 09:58 AM
probably for the license plate frame
Old Jan 14, 2020 | 10:03 AM
jc411's Avatar
Makes sense, thanks. I just installed the disc plug under the hood (thanks for posting the picture) and two gaskets under the car, all of which were not installed by the dealer.
Old Jan 27, 2020 | 02:29 PM
Wander's Avatar
Did they pull the shipping plastic off the car, or did you get to do that too?
Old Jan 27, 2020 | 03:11 PM
jc411's Avatar
They removed most of it but I did remove the plastic off the infotainment screen, the door trim, and the front hood release.
Old Jan 29, 2020 | 05:04 PM
So the TQI shows two spots that obvious spots that they want the body plugs installed. If you look at the front of the image it looks like there are two more bold circles where they want plugs installed but its more subtle. Curious who has two, four or six installed? The 5th and 6th ones would go just in front of the rear wheel - there is another hole there..
Wander
3G RDX (2019+)
43
Jul 28, 2021 05:08 PM
Bmosbacker
3G RDX (2019+)
Feb 22, 2020 07:29 PM
RVator
2G RDX DIY & FAQ
Oct 5, 2019 07:49 AM
lumn8
1G RDX (2007-2012)
22
Feb 23, 2018 12:59 PM
pdpunome
1G RDX Problems & Fixes
Jul 15, 2016 06:39 AM
