Which spark plugs for 2015 3.5L RDX
Old 09-29-2017, 03:54 PM
5th Gear
RVator's Avatar
I am looking to replace the plugs. I have found two different ones that are supposed to OEM. Have not looked at the ones in the car yet. NGK - ILZKR7B11 and Denso - SXU22HCR11. Which one is right?
I have seen a few different versions with an "S" attached either at the end or beginning. I am guessing the heat range is 11, but I really don't know how to decipher the designations. Can anyone help?
Old 10-01-2017, 08:50 AM
fcostantini's Avatar
The owner's manual for my 2017 RDX allows for both spark plug types:
Acura apparently believes that they are interchangeable. I don't have an opinion about the relative merits of NGK vs. DENSO.
Old 10-01-2017, 08:56 AM
Sorry for the bad picture pasting above. 2nd try...
Old 07-07-2018, 05:39 PM
inmydream316's Avatar
What about gap spec? Cant find its gap range
Old 07-08-2018, 08:19 AM
The correct gap is 0.044" according to the product listings on RockAuto for Acura's recommended DENSO SXU22HCR11S and NGK ILZKR7B11 spark plugs.
Old 07-08-2018, 08:28 AM
i got it. Thanks!
Old 01-18-2019, 12:09 PM
2RudeRudy's Avatar
Great post!! I'm new to the forum and I have a 2014 RDX 3.5L and it's coming up to about 90,000KM and I wanted to change the plugs. Is this a DIY or do I have to take it to the dealership? I can't find anything point to where the location of the plugs are or where how to replace them yourself. Any assistance would be very much appreciated. Thank you everyone!
Old 01-18-2019, 08:13 PM
egads's Avatar
Why so early? The Multi Information Display will set a code for them around 160km (100k miles) You only have 56k miles.
You can search other Honda forums for vehicles that use this v-6 engine for tips.
Old 01-19-2019, 10:13 AM
There are many videos on Youtube that will help you if you decide to do it yourself. Search for "acura j35 spark plug replacement" and the MDX, odyssey or pilot will be applicable to your RDX.
Some things to remember:
1) Do not use anti-seize or other lubricant on new plugs. They are coited with a finish that prevents them from getting stuck. If reinstalling old plugs, a "tiny" amount could be used.
2) Double check the gap before installation
3) Use a torque wrench for proper tightening.
Good luck!
Old 10-04-2019, 04:36 PM
Rdx2017's Avatar
Good luck!
what are the torque on the spark plugs???? I have a 2017 RDX..
Old 10-05-2019, 07:00 AM
13 ft/lbs is the torque spec for the spark plug (156 inch/lbs).
Old 10-05-2019, 07:49 AM
dave08902's Avatar
Here is the Factory service manual on coil and spark plug replacement.
Hope this helps.
Tech (04-18-2020)
RVator
2G RDX DIY & FAQ
26
11-20-2019 01:10 PM
reinhars
1G RDX (2007-2012)
14
02-21-2019 09:36 PM
SyberKnight
09-05-2017 02:07 PM
rayrrr
07-17-2017 06:13 PM
Quick Reply: Which spark plugs for 2015 3.5L RDX
