First maintenance & oil change?
Old Mar 6, 2019 | 05:40 PM
SuperJ203's Avatar
3rd Gear
Hi guys,
Just wondering when I should take my rdx to get first maintenance?
I've owned it for about 4 month, but only at around 900 miles (yes I drove way less than I expected, but still love my new rdx so much!)
The oil monitor is at 80% now.
I did see people mentioned one can just go with the monitor: whenever it drops to around 20%.
But for me that will likely to happen after I've owned it for maybe one year? Isn't that too late?
Any thoughts will be appreciated!
Old Mar 6, 2019 | 05:43 PM
MI-RDX's Avatar
Everything I've heard and read says to go in when the OLM says it's time - or - 1 year, whichever comes first.
Old Mar 6, 2019 | 06:38 PM
mode360's Avatar
I would agree with the post above, either go by the maintenance minder or 1 year, whichever comes first. I drive several vehicles so I can never go down to 20% in a year but I do change it annually.
Old Mar 7, 2019 | 01:16 AM
Wander's Avatar
The usual advice is that if you DIY an oil change before the MM requests it, you should NOT reset the MM. Doing so may cause you to miss other services that were flagged to be requested along with the next oil change.
( An ironic potential consequence of trying to be proactive and "do the right thing" ).
If a dealer does the oil change, they can check for stored service requests with their scanner.
Old Mar 7, 2019 | 05:56 AM
ToniRDX19's Avatar
Any idea what those service(s) could be? Can I use the maintenance manual / schedule that list what item to check or replace based on “Service A” it “B”?
I bought my vehicle for 4 months now and put on only 1500 miles. Oil life is at 70%. I plan to replace the oil in June regardless but never thought to not reset the MM. Oil is cheap.
Old Mar 7, 2019 | 06:40 AM
quantum7's Avatar
If you do all of your basic service, set up a spreadsheet in Excel and use the maintenance manual to set the change intervals. I have done this for several of our cars and it works great. I do reset the MM but I know what is due and when. I don't want the light flashing and the beep reminding me after I have done the work. The manual is pretty clear on when to do what and I keep the spreadsheet up to date, so I know what is due next and when. I keep my cars for a long time so I tend to service a bit sooner than I need to. As you said, oil is cheap esp if you do your own work.
I believe that there is a thread (maybe in the TL forum) about the various spreadsheets that people use. I list everything and have spaces set up for notes for any service that I do. On some of my cars I would let the dealer do the service for the first year or so (I typically put on about 30k per year) until the 3year/36k is up....just in case there is an issue so they know that they are the only people who have worked on the car. I once had a dealer strip the drainplug on the oil pan. They wanted to charge me for a new one. I reminded them that they were the only people to work on the car. They paid for the new pan and then I took over doing the work.
Old Mar 7, 2019 | 12:03 PM
Dereileak's Avatar
really until you hit a year or the miles it’s a total waste to change the oil, the oils now days are very refined and do not lose their lubricating abilities as fast, it might make you feel better but the cars engine isn’t gonna see any difference
Old Mar 7, 2019 | 01:24 PM
Wander's Avatar
The first service aside from engine oil will be rear diff fluid @15k miles, so you are fine for the first oil change no matter what you do.
The owner's manual no longer lists service intervals, but some of them can be guessed from the notes on "severe service" because that requires half the normal mileage interval. Others we assume haven't changed since the days before MMs, and anecdotally they seem to match the MM.
Look at the thread "rear differential fluid change", in "DIY and FAQ", for instance.
Old Mar 7, 2019 | 01:56 PM
Dereileak's Avatar
I wonder what a dealer charges for transmission and diff fluid changes, they are extremely easy to do yourself, drain fill done. The transmission and front diff will require the car be raised and level, the rear could be done without lifting it
Old Jun 17, 2019 | 10:37 AM
OAcuraFanBoyO's Avatar
I just got a used 18,000 miles RDX 2019, and the only thing that had been done so far on it were 3 oil and filter changes (~at every 6,000 miles).
Is there anything I am missing? What should I do next?
Does changing oil by yourself or at a non Acura dealership void the warranty?
Old Jun 17, 2019 | 06:10 PM
Madd Dog's Avatar
Was it done by a dealer? If so, ask if the transmission and transfer fluid has been changed. If not, do so.
Also, pay attention to the tire pressures, you want all 4 wheels to have virtually the same pressure, don’t count on the alarm.
Old Jun 17, 2019 | 06:49 PM
I just checked the service records, yes the rear fluid has been replaced as well.
After paying close attention first oil change was done at 10K miles and second was done at 14.5K miles, hhmmm looks like the first was delayed....
Yes it was all done at Acura dealer, so I think they know what they were doing.
Old Jun 18, 2019 | 06:23 AM
Only the rear differential fluid was changed, but it was done at Acura completely.
Also does it ruin the warranty if we do out own oil change? Any idea?
Old Jun 18, 2019 | 04:25 PM
nick04tl's Avatar
I have worked at an Acura dealer since 2004. I have never seen a warranty claim denied for using an outside shop to change the oil. You will be on the hook for a new oil pan after they reuse the crush washer a half dozen time and pull out the threads. That I see quite often from Walmart, Jiffy Lube and AAA.
Old Jun 18, 2019 | 05:59 PM
Dereileak's Avatar
Says right in the book you can do your own work, just document everything, I’m about to do the second oil change and rear diff fluid, currently at 12k miles, at 15k I may do a tranny fluid change, it’s cheap and I am thinking of doing the extreme maintenance path, then 30k each time after
Old Jun 19, 2019 | 06:09 AM
I guess I have to read the book some time. I will try to do my own oil change and rear diff fluid changes as well. At least the basic work and hope to keep it running healthy for the long term.
It would make it much cheaper even if I did oil change every 5K lol. It costs around $130 at Acura. But they do some basic other checks I guess.
Old Jun 19, 2019 | 12:51 PM
oz13ms's Avatar
Just got my oil changed at 7,500 miles. Maintenance reminder was at 5%; bought in Sept 2018. Dealership charged me $99, but gave me a $50 discount since I was a new service customer.
Old Jun 19, 2019 | 02:02 PM
quantum7's Avatar
Good for you.....Doing your own basic work will save you a ton of $$$$. This site and YouTube will walk you through almost every basic job, and depending upon your comfort level with learning you can do almost any work on your car. Get some good tools, set up a spreadsheet (see start of thread) and take it slow. I quit taking my 07TL to the dealer years ago when they wanted $1100 for a radiator replacement. I did the job for about $175 and a Saturday. TL currently has 289000 miles on it and it has not seen the dealer in years. Check out the garage section on this site for more information and post questions when you have them. Dealer charge just way too much.
Old Jun 20, 2019 | 07:09 AM
That is good to know. I hope there is nothing major for some time on this car.
Plus I was really hoping it would be easier to work on these cars compared to German. I had an Audi in the past and the repairs were getting hectic so I traded that in for the RDX.
That is great news on the TL, hoping to keep this Acura RDX going for that long as well. For now I will start off with the oil changes, my first step. Acura is charging $130 and I think I can have it done in like $30?
Old Jun 20, 2019 | 07:12 AM
But lately Take 5 has been pretty good as well, they do a decent job and it gets done in no time. I think they were charging like $50-60 for oil change on this kind of vehicle, however, I always thought if we did not get the oil change / maintenance done at Acura the warranty would be void. I did not care about this factor on my subaru, I did my own thing since day 1 or took it to a private mechanic that I knew very well. It did not have any issues till 70K until I got rid of it.
Old Jun 20, 2019 | 04:05 PM
EXCALIBUR1's Avatar
Has this ever happened to you? I was waiting to do my own first oil change and tire rotation when I received an email from Acura of Honolulu for a complimentary A1 service. Now that was an offer I couldn't refuse. In addition to an oil change and tire rotation, they even replaced the front wiper blades, performed a "multi-point vehicle inspection", and "express car wash and vacuum." The dealership has a fabulous waiting/lounge area, complete with coffee/hot chocolate, snacks, TV, and Wifi. I could get used to this VIP treatment. Acura been very good to me!
Acura of Honolulu <youracuradealer@emails.acura.com> Unsubscribe
Wed, Apr 17, 2:15 PM
to me
This message contains graphics. If you do not see the graphics, click here to view.
WITH PRECISION CRAFTED SERVICE,
YOU GET MORE THAN THE SUM OF ITS PARTS.
The expertise of Acura-Trained Technicians plus Acura Genuine Parts and Fluids plus a special offer—it all adds up to a great value on maintenance for your RDX.
Present this e-mail during your next visit and receive a complimentary A1 service
Our techs will:
Replace your engine oil and oil filter
Rotate your tires, and check tire pressure and condition
Complete a multi-point inspection
Offer valid through 06/30/2019
VALUE NOW, VALUE LATER
According to Kelley Blue Book's KBB.com, regular maintenance for your car including car washes, oil changes, tune-ups and tire rotations can help your vehicle retain its resale value.*
In and out in 60 minutes or less.
No appointment necessary.
Acura of Honolulu
3251 N Nimitz Hwy
Honolulu, HI 96819
Service Hours
Mon - Fri 6:30 AM to 5:30 PM
Sat 7 AM to 4 PM
Call an Acura-Trained Service Consultant at (808) 942-4555
*From "How to Maintain the Value of Your Car" on Kelley Blue Book's KBB.com. Kelley Blue Book is a registered trademark of Kelley Blue Book Co., Inc.
Offer valid through 06/30/2019. Maintenance requirements, schedules and prices may vary by model. Synthetic oil is additional. Offer does not apply to tires or sublet repairs. Not to be combined with any other discounts. Plus tax where applicable. Hazardous disposal fees are extra. Present coupon at time of write-up.
You are receiving this e-mail based on your ownership history with Acura. Acura of Honolulu is participating in a program sponsored by Acura to provide you with the most recent information to ensure timely service of your vehicle.
To unsubscribe from future promotional e-mail communications from Acura of Honolulu and to update your preferences, please click here. Please do not reply to this e-mail.
Acura of Honolulu
3251 N Nimitz Hwy
Honolulu, HI 96819
Old Jun 21, 2019 | 07:18 AM
quantum7's Avatar
Sounds great....but the commute for the free service would cost me about $4000.
Old Jun 21, 2019 | 11:02 PM
anoop's Avatar
How much does the A1 service run? I'm going in next Tuesday.
Old Jun 22, 2019 | 04:05 AM
EXCALIBUR1's Avatar
You could think of it as a $4,000 A1 Service and a FREE vacation in Hawaii Five-O.
Old Jun 22, 2019 | 05:21 AM
quantum7's Avatar
I am heading to the bank right now to get cash....Aloha!
Old Jun 23, 2019 | 06:51 AM
desmedt's Avatar
For DIY oil changes, what oil to use? Acura oil is NOT synthetic, right?
Also where do you buy your filters?
__________________________________
2019 RDX Tech SH-AWD
Old Jun 23, 2019 | 01:50 PM
securityguy's Avatar
Pennzoil Platinum is the only oil I use in any of my vehicles. I use OEM or Mobil1 filters I buy at Walmart cheap.
Old Jun 24, 2019 | 12:35 AM
Dereileak's Avatar
I’m running mobil1 advanced
jguerra23
Jun 29, 2008 05:50 PM
JackSprat01
May 26, 2008 11:56 AM
yadfgp
1G TSX Problems & Fixes
Sep 21, 2006 09:52 AM
RavenHwk
Dec 8, 2003 04:41 PM
Boeing747
Jan 16, 2001 12:40 AM
