Engine braking
Old Mar 26, 2022 | 01:31 PM
anoop's Avatar
Engine braking
This is my first auto car, and only recently noticed for the first time that the car does engine braking under certain situations. The case where I noticed it is where I was on a slight downslope, I hit the brakes, and then released. If found that the car downshifted and stayed there until I attempted to accelerate again.
Old Mar 27, 2022 | 08:27 AM
ELIN's Avatar
Some makes call this “hill assist”, I think.
Old Mar 27, 2022 | 09:37 AM
anoop's Avatar
I think hill assist refers to application of brake when in D and stopped on an upslope to prevent rolling back.
Old Mar 27, 2022 | 09:53 AM
NooYawkuh's Avatar
Skeptic
Yeah, I've noticed for years that newer automatic transmissions would downshift if you're off the gas going downhill and you tap the brake. If that's not enough, you could always have switched to L. My Pilot had L1, L2 and L3, where it wouldn't shift beyond the selected gear. Handy when driving in a hilly area.
Yes, I've noticed that the RDX seems to have that "hill assist" feature. Plus, you always can switch the transmission to Sequential and use the paddles. That's what I do driving on back roads on the north shore of Long Island or the hills of Western Connecticut.
Old Mar 27, 2022 | 09:59 AM
NooYawkuh's Avatar
Skeptic
I've heard that called "hill holder" or brake hold but it's a different feature. The RDX has it and you can turn it on or off with one of the buttons on the left knee panel. I leave it off.
Old Mar 27, 2022 | 02:48 PM
ELIN's Avatar
Yeah, that's "brake hold".
Old Mar 27, 2022 | 03:53 PM
Showkey's Avatar
Honda use to call it grade logic:
The grade logic is downshifting to maintain your speed as you coast down a hill. It takes no input from the brake pedal. All it does is detect speed increase and decrease. If you apply the brakes obviously there is no need for engine braking.
During hill decent with foot off the throttle or light throttle the transmission will hold the present gear and not up shift……..controlling the speed using engine braking.
Old Mar 27, 2022 | 05:57 PM
NooYawkuh's Avatar
Skeptic
Grade Logic - that sounds familiar. I think that's what my Honda Pilot had.
Old Mar 27, 2022 | 07:41 PM
Chipdull's Avatar
Honda had been using the “Grade Logic” branding within their AT for a long time. It’s mentioned as a feature on the 1994 Accord
Available Electronically-Controlled 4-Speed Automatic Transmission w/ Lockup Torque Converter and Grade Logic Programming
https://hondanews.com/en-US/releases...wagon-features
And here’s a press release talking more in-depth about the transmission on the 2001 Prelude
https://hondanews.com/en-US/releases...e-transmission
Brings back memories eh?
Old Mar 28, 2022 | 12:18 AM
hans471's Avatar
I was with Chrysler back in the mid 1990's and the Mitsubishi cars had some out with a similar type program. They first called it "Fuzzy Logic" which was more commonly used in Japanese vehicles at the time. I think someone decided to drop that name (which is the correct technical term for it) because some consumers thought the computer was confused or something.....
"Firms such as Boeing, General Motors, Allen-Bradley, Chrysler, Eaton, and Whirlpool have worked on fuzzy logic for use in low-power refrigerators, improved automotive transmissions, and energy-efficient electric motors".
Old Apr 12, 2022 | 08:49 PM
Jerzy's Avatar
Driving thru Rockies I found that cruise control does not work on very steep downslope. Setting drive mode to "S" instead of "D" as well as setting Sport+ mode helps to keep it within desired speed without using brakes. On the other hand I found in many places in Utah "No Engine Braking" sign.
Old Apr 12, 2022 | 09:54 PM
anoop's Avatar
I think that sign is more for trucks. The RDX engine barely makes any noise.
Old Apr 13, 2022 | 07:27 AM
NBP04TL4ME's Avatar
Stay Out Of the Left Lane
Trucks that "Jake Brake" can make a lot of unwanted noise -
OldZaskar
3G MDX (2014-2020)
Jun 26, 2019 05:41 PM
Time For Sleeep
Jan 4, 2005 10:18 PM
ks112
Jul 10, 2004 12:31 AM
Severin
Mar 19, 2003 11:01 PM
canektid
Oct 18, 2002 10:50 PM
