Check oil level
Old Dec 22, 2024 | 04:03 PM
24RDX_Owner's Avatar
Check oil level
Hey all,
Looking for dome assistance. Just had my first oil change. Manual says 4.8L with filter. Poured 5L jug.
The dipstick with the orange piece is horrible...I can't tell if I have enough or not.
Are we supposed to check the light coating on the orange piece or are we supposed to check the actual oil for the level?
The following pic, not enough or overfilled? Thanks.
Old Dec 22, 2024 | 04:59 PM
russianDude's Avatar
Needs to be at the second dot. I always dump 5qt, it’s fine
Old Dec 22, 2024 | 06:06 PM
I understand where it needs to be, but wondering if we confirm with the light oil film that's already above the upper mark, or bring up the darker oil part in the pic to the upper mark?
Hope that makes sense.
Thx
Old Dec 22, 2024 | 06:10 PM
attofarad's Avatar
Always difficult to see the oil level with this dipstick, especially with clean new oil. I often have to wipe and retry several times.
One thing that helps a bit it to roughen up the surface of the orange plastic with some sandpaper.
After draining the oil and changing the filter, I find that 5 quarts added puts me just above halfway between low and high. 5L would typically put you close to the high mark. If you didn't change the filter, of didn't fully drain the oil (car tilted or something), 5L could put you above the high mark.
I have found that the oil level on the dip stick will change quite a bit, depending on how long the engine has been shut down, maybe 0.2 quarts or so.
Old Dec 22, 2024 | 07:00 PM
The image below is what I see after filling with 5L jug.
That's what I'm trying to understand with this horrible dipstick. Do I measure by the height of the thin film of oil in the blue area, or measure by the height of the thick coat of oil, where the thick coat of oil (yellow arrow) should be at the upper marker?
Edit: if I'm to measure by the thick coat of oil, then I haven't got enough oil and need to top up. If I'm to measure by the thin film, then I'm way over.
Old Dec 22, 2024 | 07:38 PM
GW208's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
I find it a lot easier to check the level first thing in the morning when the engine is cold.
Old Dec 22, 2024 | 09:07 PM
rahcu2's Avatar
First wipe the dipstick dry, then re-insert the stick and remove.The level is where it is still "wet" looking, so you go by the thin film you are referring to. I agree, the dipstick makes it difficult, I need to go under specific lighting to see the transition line between wet and dry on the dipstick. A little bit overfill within the orange section won't hurt anything
Old Dec 23, 2024 | 05:42 AM
Thx
your picture does not clearly show the level. Make sure to wipe it thoroughly before taking a reading. It should be very clear line that separates dry and wet. I never had an issue seeing a clear line that separates wet and dry.
Old Dec 23, 2024 | 12:17 PM
Thank you all for taking your time to respond. Much appreciated.
Old Dec 23, 2024 | 01:46 PM
Baldeagle's Avatar
I fill mine to the upper mark of your blue area. And with fresh oil, it is difficult to see. It is usually a little over that top mark, especially if the engine sat for a while and all the oil settled into the oil pan.
Old Dec 23, 2024 | 02:12 PM
You are over complicating it, just dump entire 5qt and your level will be fine.+/- 0.2qt wont make any difference
CadeTL
Jan 30, 2018 08:39 AM
duckengine
Sep 30, 2009 02:18 PM
hANDYcaptd
Jul 4, 2008 12:46 PM
RippinRide
Oct 18, 2007 07:16 PM
