CarPlay issues are not limited to the RDX
According to this article, many CarPlay users who are running the latest iOS firmware are experiencing numerous bugs with CarPlay.
I have occasionally experienced
- CarPlay not booting and requiring me to turn off the car for awhile before trying again.
- 2) audio not playing through the car even though the CarPlay interface is working.
Can you explain how is the problems you are having?
My problem has been happening for months, while using multiple IOS versions, and multiple System updates that never fixed the issue.
For issue (2), I think it happens most when my phone is plugged before turning on the car. However, it's not 100% consistent with any series of events. This issue is usually (always?) resolved by disconnecting then reconnecting my phone.
What issues are you having?
Skeptic
![](https://cimg3.ibsrv.net/gimg/acurazine.com-vbulletin/800x613/applecarplay_eaba58f7529ccebacf412e38b19d8581bc49c9e3.png)
then you need to continue narrowing it down, I never have carplay issues anymore, could be lint in your charging port, a crappy USB cable, or 100 other things
My issue, and many others at an Apple Forum is that Apple CarPlay drops after 5- to 8 minutes connected (3 out of 5 times), and stays disconnected (not even allowing USB Music or plugging and unplugging the same or a different phone or USB device) for another 5 to 8 minutes. After that, connects again just to disconnect after 5 to 8 minutes. The only solution is to turn car on and off (open door of course) and try again, and pray that it would be the 2 out 5 that works!
You can see the problem on this link:
I tried multiple cables, brand new ones, different phones. No luck. Multiple system updates and iOS updates, also no luck.
At this point, I am hopeless.
I've used carplay on a daily basis since buying my 2020 RDX in October and never had that issue once. I do use an actual apple cable and I have an iPhone X. I've seen soooo many third party cables that even when brand new are dodgy for any data interface. I use them all the time to charge the phone, no problem, but then I try them on my Macbook and they disconnect constantly. If I use actual Apple cable it works every time. I have found also with the many rental cars I've had over the last year that CarPlay is stable across a number of manufacturers.
Try this - use canned air to blow out the lightning port on your phone and the USB port on the car. Factory reset the infotainment system and then use actual Apple cable and see what that gets you. If it still disconnects like that, I'd wager the USB interface on your car has issues.
Have you attempted to repair your iPhone with the car? Delete all remembered iPhone connections in the car and delete all existing cars from the iPhone. I had problems when iOS 13.0 was first released, but only on my new iPhone 11 Pro Max. My old iPhone XS Max worked perfect though. Once I deleted all existing connections and upgraded to 13.1.1 beta, the phone worked flawlessly. It's worked flawlessly ever since.
Did you recently upgrade your phone? It could be a glitch in your restore file when you upgraded phones.
Over on the Apple support communities site, many 2019 -2020 RDX owners who have been suffering from CarPlay disconnects have noted recently that performing the factory default reset in their cars has, at least for now, stabilized CarPlay & resolved the disconnect problem. NO ONE believes this is a permanent fix, but it seems after the last firmware update, resetting to default seems to be working for now. It’s been working for me for about a week so far, so I’m keeping my fingers crossed. We all noticed that the Android Auto icon is now available & that may be some indication of a new level of stability. Who knows?
I have similar issues
every 2to3 days I have to do a Factory Data Reset
to have the Navi system recognize my iPhone 8
sometimes after it resets my sound system only plays thru 1 speaker
the one behind the Navi screes
in this case a second FD reset is required
i have brought my Rdx 2020 back to the dealer 4 times
i have conversed with Acura car play tech support
and I have have numerous conversations with Apple
no one seems to be able or willing to help
its a blame game
if anyone has had similar issues and has any ideas
I would be extremely appreciative
thanks to all who have read thsi
it really staeted a few months back with an Acura link software update which said it would run for 15-20 minutes
it only ran for 5 seconds
Very very frustrating
its a blame game
its a blame game
its a blame game
its a blame game
its a blame game
I wouldn't say zero hiccups, but definitely less hiccups. Also, people shouldn't have to choose a lesser connection because the automaker can't get proper engineers/coders for their infotainment system. Don't offer an option if it is only half-baked just to check a box. UX is a long memory for many customers in their future purchasing decisions.
Stay with Acura???
After the first 18 months of ownership, CarPlay stabilized somewhat on my 2019 RDX. I still get an occasional unavailable, but it’s seldom and it usually clears up after restarting the engine. After loving my 2009 TL and being disappointed in the infotainment system in the RDX, I’m wondering about wireless CarPlay and charging in the 2022 MDX. Has anyone heard anything about CarPlay in that model?
Slack Machine (04-08-2021)
A '22 MDX owner in another thread complained that they couldn't have a USB plugged in and use wireless CP at the same time (ie. same boat as those of us w/o wireless CP). They only have the convenience of not needing to connect the lightning cable.
Before anyone asks, folks like me would prefer to keep and play our hi-rez music on USB while simultaneously using CP apps (like Waze).
markm929 (04-08-2021)
Now believe it or not I am not that interested in a MDX anymore after the test drive. Compared to the RDX its not as agile as my 2019 RDX ASpec. I am hoping when my lease is up in September the 2022 RDX's are out and have been upgraded to wireless CarPlay and whatever updated infotainment system/hardware that's in the 22 MDX.
Wireless carplay would be a welcome addition....as long as you don't care about playing hi-rez music via USB at the same time.
Imagine my surprise to hear that a non-Type S MDX weighing a good 500 lbs more is "not as agile" as a 2019 RDX A-Spec. You would need to get the forthcoming Type S to have anything close to "agile."
I stopped paying for Amazon Music HD when I realized I could never play better than really, really good CD quality music (nothing approaching SACD or DVD-A and definitely not BD-Audio quality).
If we're talking CP/AA, the weakest link is always the phone.
The service's capability is different than the device's capability. Back when I had Amazon Music HD, my app reported that my iPhone was only capable of outputting 24-bit 48 kHz. You may be playing FLAC's but your phone is the limitation. You can also forget about multichannel tracks (Amazon Music's version is called 3D) as those will only play via home devices like receivers or USB stick only (where the car does the processing). FWIW, our Acuras can do MCH FLAC's at 24/96 and stereo FLAC's at 24/192.
ELIN (04-08-2021)
ELIN (04-08-2021)
At the end of the day, the majority of people can't tell the difference b/w lossy and lossless audio and that's the reason why mp3's and similar compressed audio are so popular!
@ELIN So true, that’s why I only listen to RP and Apple Music as they are lossless and fine by me. MP3’s suck. On another note you should have seen what the audio world was like 50 years ago, I had the Macintosh, Nakamichi, Planar speakers, subwoofer, etc setup. Super expensive in those days. Big improvements since then for sure……
Who really believes Apple car play works intermittently because i’m not using the official Apple brand cord !
Why won’t Acura or Honda admit there are other people besides me with Apple car play issues
Why won’t Acura try to fix the issue
Why do they tell you their policy is for the customer to call Apple but I’m the only one complaining, then why do you have a policy
Why do they seem to not care
Why does Acuralink promise to call you back but never follows up
Why would I ever but another Acura
Just POOR customer service
tecwerks (04-09-2021)
Have you brought it to the dealer? Keep harassing them until they fix it. The infotainment is an integral part of the vehicle and may be subject to Lemon Law in your state. Funny ... I punched in "Lemon Law infotainment" in Google and all the top hits pertain to Honda's infotainment. Having to reset it 3x a week is beyond excessive IMO.
No amount of software is going to fix the old hardware that Acura is using. You’re using hardware and software from 2014/2015. It’s a memory issue that causes the crashes. Plus all the other stuff that is running in the background constantly. The 22s have switched chipsets which work better to handshake with iOS and Android. There really is no fix but a hardware and android os update for the RDXs.
