anyone else have a problem with the chrome trim on the sides of the shifter?
I have had several instances where I get blinded from sunlight being reflected off the chrome trim on the passenger side of console where the shifter/transmission buttons are located. The only way I can keep driving is to place my hand on that section until I make a turn, or the road turns, so that the reflection stops. See attached pic for the piece of trim I'm referring to. (Pic is a marked up stock pic, not my car.)
Has anyone else experienced this? What is your solution?
I wish there was an OEM option for a different color, but it looks like that trim is the same regardless of base, tech, A-spec or advance.
Alias1431 (06-15-2019)
Drive on a dirt road with the windows down. Problem solved.
anoop (06-18-2019)
anoop (06-18-2019)
anoop (06-18-2019)
I also had this issue. I like to keep the roof cover open because it feels so much bigger that way, so i decided to add additional tint to the roof. Problem solved. The only time I get significant reflection on the consul now is when it is coming from another source.
anoop (06-18-2019)
Null and proud of it
Random chrome bling everywhere is a new car trend. Not that chrome is, but it's used in weird spots these days.
Look at how much chrome/piano black was added for the 2016 Accord MMC that wasn't originally there for the 2013 release...
subin (06-16-2019)
You should go to a car shop that does vinyl wrapping and see if they can vinyl wrap those pieces with piano black trim to match the piano black right next to it. It will prevent any glare and is totally reversible. It also won't look out of place or cheap if done properly.
Blue (or green) painter's tape.
ckiggins
4G TL Problems & Fixes
05-11-2016 11:39 AM
Elegant TYPE S
06-15-2012 11:26 PM
vipTL
08-20-2010 05:06 PM
