AIS not engaging -- battery issue?
2023 RDX with about 33k miles, bought 3/2023.
AIS (auto idle stop) has not been engaging the last several days.
Car gets driven a lot and regularly and weather has been mild (70s-80s, low humidity as I'm in CA).
Does this mean the battery will need to be replaced? I guess they'll be checking it when I take it in next time.
If you have a voltmeter you might want to check the voltage of the battery after a reasonably long drive. With engine off, the voltage should be around 12.6 volts DC or higher. Something around 12.4 volts or lower indicates a potential issue.
Did you have to pay for the replacement (like a wear and tear item) or was it replaced under warranty?
I happened to have it in the dealership for a recall, and they mentioned the battery was bad. After I replaced it with one from Costco, the AIS returned to normal.
Mine is a 2021, and it had 99k miles at the time.
Stay Out Of the Left Lane
I have a 2020 with almost 49K on it (WFH). If it sits for a while -say a week, I will throw it on a trickle charger and 99% of the time the AIS works.
I actually didn't even look into warranty coverage - if it's like any other battery warranty I probably would have gotten a bit of money back but at the end of the day I got my replacement from Costco and have their warranty now.
According to the 2022 RDX warranty document:
"New Vehicle Limited Warranty ............. Every new Acura is covered, including the 12-volt battery, for 4 years or 50,000 miles, whichever comes first."
Seems to be a fully free replacement, as long as the 4 year/ 50k mile limit has not been reached.
I was going to buy one at Sams club, it was Duracell, but trusted Interstate more, actually paid $222 with my buddies discount.
AIS is so dumb to me, wish there was a was to permanently engage Sport +.
If you have access to Costco, Interstate is their battery supplier.
Sure with a tune it can be removed.
We're team Sam's Club, not sure why lol
Pretty sure the Sport+ drive mode locks out the AIS and you don’t need to remember to hit the AIS button each time. The potential down side is driving in Sport+ all the time.
Yes but what I was referring to, is that each time you get in to drive, you need to pop it into Sport + to not deal with AIS or turn AIS via the button each time. It sucks that setting has to be toggled each drive cycle. stupid EPA BS
Another consideration, at least for some of this time of year, is the use of the seat warmers. Couple their use with the stop/start of AIS and relatively short trip driving and you have a perfect scenario for running down the battery.
I don't use seat warmers at all. But I like the silence and zero NVH from AIS when sitting at a light.
Battery sensor?
BTW, if it was not covered under warranty, service advisor said battery replacement would have been $350.
Service advisor says they contacted Acura and they were told that the system goes through a learning process after the battery is replaced so it can take up to 2 weeks before the AIS starts kicking in normally. In the mean time, temperatures have dropped here quite a bit, so it may be a while before I find out whether the system is actually working.
Assuming they don't fix this, I'll be sitting on 2 unresolved issues
- Squeaky brakes
- AIS not working
Not happy about this. I think I may have to contact Acura and have a chat with them.
There are some steps in the procedure at AIS relearn that might be worth a try. No guarantees they would work but i don't see any chance of harm.
If it does not work after your battery is fully charged, you most likely need new battery. The load test they do might not always identify the issue.
its BS. I had my battery discounted and reconnected,
and AIS worked immediately.
I also sent an email to Acura last night.
Are you thinking the battery they put in may be defective?
AI/Grok said it might be the alternator, the ECU, or some other electrical issue.
if you have charger, charge you battery fully and it has to start working immediately or you have a problem. There is no 2 weeks wait, its BS.
could be other issues too, but there is no 2 week wait after disconnecting
