Aero Underbody Panels
Old Jul 19, 2018 | 02:42 AM
ednigma's Avatar
Does the 19RDX have aero underbody panels? Saw a thread on the Mazda CX5 regarding an oil change and the CX5 uses sound absorbing panels that improves underbody aerodynamics and helps to quiet road noise. Even saw a Youtube review on the Audi Q5 showing the rear control arms have fairings for aero dynamics in a addition to aero underbody panels. Just curious as I don't recall seeing any pictures or video showing the underbody of the RDX
Old Jul 19, 2018 | 05:17 AM
MarineOne's Avatar
Aerodynamic Tailoring
A comprehensive aerodynamics package helps the new RDX achieve top-class fuel efficiency and interior quietness. Specially-shaped components at the front of the vehicle guide airflow through the engine’s radiator and into the turbocharger’s lower-mounted intercooler, while channeling the remaining airflow over, around and under the vehicle. A cold-air intake is also provided for the engine.
Additional aerodynamic details include:
· Minimizing the inlet opening area at the front of the vehicle
· Small vents built into the front fenders create “air curtains” that help maintain smooth, attached airflow across the wheel openings to reduce drag.
· Molded under-panel located directly beneath the front air dam smoothly initiates the rearward flow of air underneath the vehicle
· Aluminum under-tray positioned beneath the engine and transmission smooths underbody airflow
· Lateral strakes deflect airflow around the front tires to reduce drag
· Dual molded side under-panels improve airflow between the front and rear wheels
· Rear spoiler positioned above the rear window helps air separate cleanly from the vehicle
Old Jul 19, 2018 | 02:22 PM
Dizzyg12's Avatar
I can tell you if you look under the car there is a foam spray, and there’s a foam in various holes....would that be part of the underbody aerodynamics? Certainly cuts down on road noise
Old Jul 19, 2018 | 02:40 PM
Russell Dion's Avatar
Cutting down on road noise is exactly what that foam is for, I can't comment on aerodynamics.
hoadinh504
2G TSX Performance Parts & Modifications
Sep 25, 2012 05:41 PM
bforbrian
Aug 1, 2010 02:29 PM
TSX_Mambo
May 25, 2007 02:40 AM
baddbenny
May 4, 2007 11:39 AM
djbnyc
Oct 18, 2004 11:08 AM
