Wanting to confirm correct fluids for Transmission fluid change
Hello all, I have spent hours researching and before biting the bullet, I want to confirm I have all the correct part numbers. Would love to know most cost effective way of acquiring these also. I am in Houston TX if that helps.
Transmission change parts:
- 2 bolts replacement -- 06237-5J4-010
- 4 qts of ATF-TYPE 3.1
Rear Differential parts:
- 2 qts of Acura All Wheel Drive Fluid DPSF
- 2 new Washers (what size?)
Transfer Case parts:
- 1 qt of Acura Hypoid Gear Oil HGO-1 / Any other GL-5 75W-85
I dont plan on doing the work myself as I don't have any of the required tools nor the confident / expertise to complete these jobs. I just want to provide my mechanic with all the parts needed so he can complete the job. Your help is greatly appreciated!
I don’t have the answers to your question but be aware there were three different transmissions available 2014-2020, check your owners manual for the correct fluid.
rodleung68
1G TSX Problems & Fixes
05-05-2012 11:58 PM
