Hybrid transmission fluid change
I just picked up an 2018 sport hybrid. Couldn’t find much info on this. But is the procedure for draining and filling the transmission fluid the same as for the non-hybrids? I know that the hybrid uses ATF-Dw1. Any other helpful tips?
TIA
TIA
mrgold35
I have a 19 MDX hybrid (22,000 miles) and a 18 RLX hybrid (16,000 miles). How many miles do you have and do you have the records of any previous maintenance? It has just been for each:
- 2 each oil changes (dealership),
- new cabin and engine air filter (DYI)
- one each rear diff (Twin Motor Unit-TMU) at dealership with DW-1 oil changes at around 15,000-17,000 miles
- 7DCT software update for both
It has suggested by +14 RLX hybrid owners to change the 7DCT fluid every 30,000 miles to keep it happy (I will keep the same schedule for the TMU). I will just take the hybrid to the dealership when my 7DCT is due for a fluid change.
Side note: The 3.0L V-6 only takes around 4.5 qts of oil; while, the 3.5L MDX takes 5.7 qts of engine oil. Some hybrid owners (including me) found out the tech wasn't paying attention and put 5.7 qts. The hybrid is such a low volume vehicle, looks 99% like a 3.5L MDX, and very trouble free to be seen on a regular basis in the dealership's shop.
Zz916zz (04-26-2021)
Thank you for the info mr.gold. It’s at 29k, no maintenance records, the only ones I see are the ones on carfax. I found the thread for changing the fluid on the TMU but none for the transmission. Wanted to tackle both, but if it’s difficult then I will just bring it to the dealership.
mrgold35
I'm thinking what should have been done by 30,000 miles:
- 3 oil and oil filter changes
- 2 or 3 tire rotations/balance
- new cabin filter
- new engine air filter
- rear TMU change at 15,000 miles
- 7DCT fluid change
- 7DCT transmission odd gear TSB #20-039 update
I agree with you about changing out the 7DCT and TMU fluids just to start fresh. The only PITA is you won't be able to reset the M.I.D. maint code for the 7DCT or TMU if it didn't pop up in the dash. The Acura tech can reset individual codes. You might do your 7DCT/TMU fluid changes at the same time you need to do the TSB #20-039 to reset those individual codes?
- new cabin filter
- 7DCT fluid change
Just had the tranny fluid done on my 19 MDX. Not cheap, $600 CDN. I said what is this vehicle a BMW to the dealer? I understand with the push button transmission, which I do not like, it is a costly change. My 14 RDX is more than half that. As a long time owner of Honda and Acura products, I don't fool with their transmissions after the fiasco with my 2002 TL. (4 trannys - Acura paid for them all).
You will need to lift the car front and rear to make sure it stays level.
Next make sure you can remove the fill ports, Last thing you want to do is drain the fluid and find the fill bolts stuck!
Drain , reinstall the bolt, fill till fluid drips out the fill port.
On the rear, that's it.
On the front the next step was to do a diagnostic mode, start the engine which I can't recall directly, involves incantations with the info display buttons.
Then check the fluid level again and add more if needed
I think there is either a detailed discription of the transmission fluid change in the sticky's or in a post I or someone else made. outlining the transmission level check
It was "easy peasy" for me on my 19 hybrid. Transmission and rear unit both use the DW-1 fluid. Drain/fill is basically the same
just curious, what’s the reason to put in diagnostic mode after changing the fluid?
Here is how to enter maintance mode: Virtually every warning and dash light will be on in maintenance mode. don't worry about that.
Maintenance Mode
1. Turn the vehicle to the OFF (LOCK) mode.
NOTE: Do the following procedure within 60 seconds to
start the engine in the maintenance mode.
2. Turn the vehicle to the ON mode without stepping on the
brake pedal.
3. With the transmission in P position/mode, press the
accelerator pedal to the floor twice, then release it.
4. Shift the transmission to N position/mode while pressing
down on the brake pedal, then press the accelerator pedal
5. Shift the transmission to P position/mode while pressing
6. Press the power switch while pressing down on the brake
pedal. The vehicle is now in the maintenance mode and the
engine will start.
NOTE:
Warning indicators and messages will be displayed
during any of these maintenance modes.
To turn the engine OFF and cancel the maintenance
mode, turn the vehicle to the OFF (LOCK) mode.
mrgold35
when I went to the dealership to get fluid for the hybrid transmission and TMU and asked for DW1 fluid the parts guy was adimant that NO NO NO, you MUST use the DW whatever that the non hybrid uses. I only hope the service dept would know better. Anyway I change the fluids myself. The fluids are quite different and the wrong fluid in the DCT may be bad news!!! Course that was the same parts guy that said I need to buy 6 qts of oil for the hybrid.
I am not an owner yet but I am planning to get a hybrid at end of this year when my current lease on Kia Stinger expires.
bmoua15 (04-29-2021)
mrgold35
The MDX hybrids are getting harder to find with lower mileage. A lot of folks are holding on to them because there isn't a +22 MDX hybrid (yet). Used car prices are crazy right now and they may or may not get back to normal by this winter. You might have to look in a 1/2 to 1 day drive of your location to find one in the color combo, tech level, and mileage you want by this fall/winter.
ruturaj (04-29-2021)
- new cabin filter
- 7DCT fluid change
- new cabin filter
- 7DCT fluid change
Anyway for whatever reason (based on the manual or that I'm often anal on maintenance) I changed both at 15K miles.l Normal service is 30K miles on both IIRC.
mrgold35
I haven't seen the 7DCT service yet on my MDX with 22,000 miles. Only the TMU for both at around 15,000 miles. My previous Acura's seemed to ask for a transmission service at 30,000 miles. I kinda wonder about severe service for a hybrid? Both my RLX/MDX hybrid's actually use EV mode a lot in severe city stop/go traffic (all I've been doing since Mar/20). So far, the M.I.D. hasn't changed the service intervals from my 3 previous Acura (06 TSX, 08 RDX, and 11 MDX).
Did my dct fluid change @ 50k and the fluid was clean as a whistle. Ive been sticking to that same interval for all my cars. You'll need a hand pump and a friend who knows what he's doing to complete the process. Dealers and independent shops just charge to much so do it yourself.
The following 2 users liked this post by bmoua15:
Larry_RLXHB14 (09-19-2023),
You can download the owner's manual pdf from the Acura's owner's site to look through the tech, features, and maint fluid requirements. The hybrid is such a low volume vehicle and it looks 99% like a 3.5L MDX at first glance (small hybrid badges on front fenders, blue "SH" for sh-awd emblem on rear, and one 8" orange high voltage EV cable under the hood located between engine block and air cleaner). The 18-20 MDX hybrids didn't have any significant changes between model years (Carplay was added for those model years). The 17 MDX hybrid had the older info-tainment graphics like the 14-16 MDXs on the lower touchscreen, no carplay, and less chrome/wood accents around the cabin.
I worry about not finding one when I time comes. I would sure fly anywhere in country for one though. I would be looking for 2018-2020 model year.
mrgold35 (04-30-2021)
Thank you. I will download the manual. For me hybrid MDX is technical marvel (also their mechanical SH-AWD), always happy to learn about it. I also watched the video on 7 speed transmission, I am not the mechanically inclined but it was pretty interesting.
When we were looking in Feb2020 there were some hybrid tech models around but the Advance model, which we wanted were very scarce. We were able to get one, but not our first or second color choice. And at least around here used ones on the dealers lots are few and far between and disapear fast. So, if your looking for one, I'd plan on allowing a fair amount of time, especially if you want the advance model.
Thanks. I would be looking for tech actually, that middle rear seat would be nice to have if I have a baby, I assume 2 adults would fit one on each side. I have don't have fixed exterior color as well but for interior I would prefer anything but black. My leg is broken right now, and I am supposed to recover around October, I will start looking from then till December.
a) crawling under the car on the ground and working
b) lifting each end and supporting by jackstands or front on ramps and then lifting the back
c) raising the car on a lift.
Luckily I have a ranger quickjack that lets me lift vehicles to 24". So it was easy peasy to do it myself. And going to diagnostic mode is easy as well.
well, I was able to easily do it myself. However, in order to do it correctly you will need to make sure the car stays level. that means either
