A16 Required service?
Old Mar 19, 2018 | 12:56 PM
babyduke's Avatar
For 2016 MDX Adv/Ent Sh-AWD 44,257mies
Dash reading shows A16 Service recommended. It's $240 at my dealer - Is this really necessary as I'm thinking about getting an
oil oil
change only?
At last OC, I paid $200 for B1
service service
which I thought was a wa$te.
B1
6Cyl. 0W-20 (6Qts.)
Oil Oil
& Filter Change
Rotate 4 Wheels
Service Front & Rear Brakes
Inspect Front & Rear Brakes
Inspect Parking Brake Adjustment
Inspect Tie Rod Ends, Steering Gear & Boots
Inspect Suspension Components
Inspect
Driveshaft Driveshaft
Boots
Inspect Brake Hoses & Lines (Including
ABS ABS
Check All Fluids (Level, Condition & For Leaks).
Inspect Exhaust System
Inspect Fuel Lines & Connections
A16 would be for
Rear Differential Rear Differential
Fluid Exchange (2Qts. AWD-Fld)
6Cyl. 0W-20 (6Qts.) Oil & Filter Change
Gear Gear
& Boots
Inspect Driveshaft Boots
Inspect
Brake Brake
Hoses & Lines (Including ABS)
Old Mar 19, 2018 | 12:58 PM
get the oil and differential fluid changed. that's all that it's asking you to do.
Old Mar 19, 2018 | 01:59 PM
mrgold35's Avatar
mrgold35
With a little planning and some labor on your end, you can knock the A1 or B1 service down a lot. I purchase my own syn oil from Walmart to take to the dealership, exchange my own cabin/engine filters, free lifetime balance/rotation and flat repair from discount tire, and have lifetime alignment from firestone. My dealership charges me $26 for an A1 or B1 service, plus a car wash afterwards, and they drop me off at work and pick me up when my vehicle is ready. Same price and service for the TSX, RDX, or MDX.
Old Mar 19, 2018 | 04:02 PM
jbawden's Avatar
If it wasn't necessary it wouldn't be part of the standard maintenance program. From your post I can infer you have an inclination towards cutting corners on maintenance but its important to follow manufacturers recommendation on maintenance and fluid types. Honda/Acura have numerous rear differential fluid options so it's important to check the manual for the specific fluid type you need or let the dealer do it.
whitecar2003
Jan 27, 2018 04:12 PM
whitecar2003
Jan 21, 2016 01:22 PM
thephantom
Nov 8, 2012 04:34 PM
batman
1G RDX (2007-2012)
30
Dec 5, 2008 10:21 AM
DaveGee
Jan 4, 2007 08:36 AM
