2016 MDX Front Control Arm - Need torque specs
I am replacing the front lower control arms on my 2016 MDX Adv and need the torque specs for the bolts that attach the control arm to the frame.
There are 3 bolts on the back L bracket on the front control arm
1. One 14mm diameter (19mm socket size) long with taper point that goes through the frame into the sway bar bushing bracket
2. Two 14 mm diameter (19mm socket size) bolts that attach the L-bracket tp the frame
3. One 14mm flange (19mm socket size) nut that attaches to the sway bar bushing bracket bolt
There is 1 bolt on the right angle corner bushing
1. A 16mm diameter (7/8 or 22mm socket size) bolt that attaches the control arm right angle to the frame
Note that the 2nd gen and 3rd gen torque specifications are different (very different in some cases). I am looking for the 3rd gen torque specs.
The castle nut for the ball joint - I believe this one is 58 lbft
Thanks in advance.
Thanks in advance.
ChucksCL-S
1G CL Tires, Wheels, & Suspension
Aug 17, 2008 11:40 PM
