Need Bolt Torque Spec
Hi Guys,
Went to the mechanic to get a quote to replace the front end bushings with the hyper energy ones...he quoted me $450 for both the side......
Fuck him I will do this myself. This is how I plan to do this. Will drop the lower controll arm completely and unbolt the 2 studs that hold the bushings for the upper control arm. Have spoken to a machine shop and he said that he will remove the bushings for me. If not then I will burn the bushings and chisel out the metal ring myself.
What I need from u guys are numbers on how much should I tighten the bolts when I assembly the control arms back. I dont have a manual that will give me the Kgpf/ntw whatever that is. If you guys can help me on this I would really appreciate it. Give me the tightning torque on all the bolts that hold the upper and lower contrl arm.
If you have any other questions or concrens you can let me know.
Thankx
JFK
Fuck him I will do this myself. This is how I plan to do this. Will drop the lower controll arm completely and unbolt the 2 studs that hold the bushings for the upper control arm. Have spoken to a machine shop and he said that he will remove the bushings for me. If not then I will burn the bushings and chisel out the metal ring myself.What I need from u guys are numbers on how much should I tighten the bolts when I assembly the control arms back. I dont have a manual that will give me the Kgpf/ntw whatever that is. If you guys can help me on this I would really appreciate it. Give me the tightning torque on all the bolts that hold the upper and lower contrl arm.
Thankx
JFK
neuronbob
23
Jul 16, 2019 10:48 AM
4drviper
Sep 23, 2015 07:42 PM
