Upper control arm torque specs?
Old Jun 7, 2017 | 09:45 AM
mrm143's Avatar
Does anyone know the torque specs for the Ball joint castle nut, the 2 bolts holding in upper Control arm, and the bolts under the hood for the shock towers?
It is a 2007 RL
Also does anyone know the size of the 2 control arm bolts? May need to buy that size but wanted to double check if anyone knew offhand...
Old Jun 7, 2017 | 10:26 AM
mrm143's Avatar
It is a 2007 RL
Also, do i need to load the suspension before tightening the bolts on on the bushings? jack under control arm till car raises a little?
Old Jun 7, 2017 | 09:38 PM
projektvertx's Avatar
Off the top of my head, I don't recall the exact number, but I know it's in the service manual. Unfortunately, with me being on my phone, I don't have that readily available, although it is stickied in the garage on the 2G landing page.
Old Jun 7, 2017 | 10:04 PM
mrm143's Avatar
i looked in the garage but didn't see it I'll check again and thanks again for the response
Old Jun 7, 2017 | 10:17 PM
mrm143's Avatar
so does this mean the bolt is a 10 socket because it seemed like a 14 when I was checking my wrenches. What is that rod is that just something to make it easier to hold up and I don't have to worry about it?
Old Jun 8, 2017 | 10:08 AM
BSQ's Avatar
BSQ
The bolt shaft is 10mm and the bolt head is 14mm. Yes, the rod will just hold up the control arm.
Old Jun 8, 2017 | 10:09 AM
mrm143's Avatar
So is this "ROD" needed as far as getting it lined up properly? or can i just put in one bolt at a time...
Old Jun 12, 2017 | 01:21 PM
mrm143's Avatar
Job done, moving the spring was the hardest part, just take your time...
