Stock 2014 Accord Sport wheel on stock 2010 tsx?
Looking to upgrade my stock 2010 tsx wheels. I really like the stock Accord Sport 18" wheels/tires and can get them in a package (link below). 18x8, Tires 235/45R18, same bolt pattern and bore.
I would like to keep stock suspension, will it work out smoothly? will it be flush and opinions on how it would look? Just got the ride and pretty clueless so detailed responses would be appreciated.
http://www.ebay.com/itm/2014-HONDA-ACCORD-SPORT-FACTORY-18-WHEELS-BRIDGESTONE-235-45R18-TIRES-OEM-13-14-/370957798485?pt=Motors_Car_Truck_Wheel_Packages&hash=item565ececc55&vxp=mtr
i have 19 x 8 on my wagon with a +48 offset.
I am far from flush. see pics in my progress thread.
the wheels you have will have a higher offset probably +55 so they will be in even further than mine.
i also run a 245/35 19 tire. it is almost the same as stock diameter.
I am pretty sure a 235/45 18 is going to have an extrra large sidewall.
And be much more diameter than stock/.
use a tire calc to confirm. all over the web/
rvalentino (10-07-2014)
Thanks for the info. So could someone help me put those numbers together? what is the minimum I would need to do to get this to work and look good? worth the hassel? or are these wheels/tires not going to work at all?
^it will work right out of the box.
because you arent dropped and how conservative the specs are, it will fit exactly like your stock rims....it will look the same, and be sunken in a little more than your stock wheels.
if you want them to be a little more flush, buy spacers.
try 15mm up front and 20-25mm in the rear.
those are suggested widths, you might or might not want more aggressive spacers....
Strictly to give it the "staggered" look. Some rear wheel drive cars use wider wheels and lower profile tires on the rear. The fact that the TSX is front wheel drive seems to be lost on some, and like to make the car look like it's something it isn't.
The following 5 users liked this post by htec:
crazyasiantl (04-03-2014),
justnspace (12-28-2013),
r000m101 (11-13-2014),
rvalentino (10-07-2014),
Slade037 (12-29-2013)
I am contemplating this swap as well. Sounds like the size/clearance will not be an issue, but I am worried about the effects of the extra weight on MPG, handling, braking, etc. Any thoughts/advice?
According to the wheel-size calculator, the weight will increase roughly 22% compared to the stock wheels/tires.
Acura TSX 2012 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-size.com
Honda Accord 2014 - Wheel & Tire Sizes, PCD, Offset and Rims specs - Wheel-size.com
Tire Tech Information :: Wheel Size / Tire Calculator and Custom Offsets - Wheel-size.com
