Spring Rates
Old Mar 15, 2017 | 02:18 PM
Mstsxxx's Avatar
9th Gear
Spring Rates
Im looking to get Tein Street Flex Coilovers, but I'm not sure what the best spring rates for my 2013 TSX. Front and back?
Help?
Old Mar 15, 2017 | 02:53 PM
julius071's Avatar
Please check out T-Demand Japan ????T-DEMAND(????????)
Old Mar 15, 2017 | 04:46 PM
if you have to ask....then you're not ready to dabble into spring rates....
just get the stock setup that comes with the tein flex...., as it will be what ever Tein set it too. and will be fine for your use...
now, if you added your intentions to why you want a different spring rate, maybe I can help you...
but asking a general, "what should I do" means you're not ready.
if you wanted to dabble into spring rates, you need to ask yourself why? and what are the reasons for going stiffer or softer...?
Old Mar 16, 2017 | 07:33 AM
I bought BC coilovers because you can custom order spring rates. I chose to go stiffer all the way around. Why?
To make the car balanced. I like race cars. I do not like stanced.
Fuck a stanced car. Ruins the car. Any way, the BC's stock came with an unbalanced set up...10kg up front and 6kg in the rear. To me, that is unbalanced. I want my car to shift it's weight in the corner, without being to front heavy.. you can accomplish this with stiffer rear springs.
But this is what I want and I researched WHY.
No two people are the same...So asking a general "what I should do" isn't the best question to ask.
You'll need to ask yourself why you want stiffer or softer springs
Old Mar 16, 2017 | 10:07 AM
Julius is on air
and I'm sure, HE had specific reasons on why he chose to go that route.
basically, modding is SUPER personal.
No one can answer questions on what should you do, or what the best is....BECAUSE it's all subjective and personal!!
One needs to figure out their goals for their own car.
once that is figured out, then one can plan and execute
Old Mar 16, 2017 | 11:41 AM
julius071's Avatar
Julius is on air
No reason to bow as I created a lot of headaches for myself going air. One of the reason why I went with air is because I have a crappy drive way but yes you are right on point!
Old Mar 16, 2017 | 12:00 PM
just trying to compensate for my "stanced cars are ugly" comment
Old Mar 16, 2017 | 08:09 PM
julius071's Avatar
BROlando
95
Jan 11, 2024 10:34 PM
ncxvtguy83
Oct 17, 2017 11:38 PM
AZ_ILX
New Member Introductions
Dec 21, 2016 04:34 PM
